'92 LT1 No dash illumination
unless it's raised to switch on the courtesy lights. Back lighting for cluster gauges is working but moving the dimmer slide has no effect on their brightness, although I'm not sure if it's supposed to. I have a service manual. It points to Chapter 11- but there IS no chapter 11 in either volume. go figure (8. I assume there's a supplement? I've had the car for 7 or 8 months. To put it nicely, It was 'neglected'. Finally got it to the point where last night was the first real drive, about 12 miles each way to pick up Chinese take out. (8 I did a mini-
"restore" on it- so it has new tires, interior, stereo, lots of plastic trim that had been broken or was missing. It has new slotted rotors, newer headers, urethane bushings..etc. It's really just a driver but seems to be mostly ok now except for a few last bugs. Any pointers would greatly be appreciated. If it proves reliable, maybe do a repaint next spring.
thanks!
bill
What happens when you put your finger over the light sensor by the gauge switches?
Is this only effecting the cluster or are the backlights for the hvac and switches stuck at one level.?
except for the outside temp display- nothing else is lit regardless of the position of the dimmer. Putting a finger over the sensor doesn't change anything -
thanks for writing!
bill
