Which Fuel Pump???
Old Oct 25, 2002 | 03:19 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Which Fuel Pump???
I need to replace the fuel pump 0n my '84....
What do you guys recommend?????
thanks..
tony :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Old Oct 25, 2002 | 03:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Which Fuel Pump??? (oldace84)
Though your FP differs from that with the L98, you cannot go wrong with the AC Delco unit for your car.
Old Oct 25, 2002 | 05:58 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Kragen now stocks AC-Delco fuel pumps. At least the ones here in Sacto did for my 88. Cost $69. Much better than paying the dealer over $100 for the same thing.
Old Oct 25, 2002 | 10:20 AM
UDLUV12's Avatar
UDLUV12
Stick with AC Delco.
Just replaced mine this past summer, at 151K.
I'm the original owner of my '86 Vette. Lots of mods, too.
Old Oct 25, 2002 | 10:22 AM
Corvette0096's Avatar
Corvette0096
AC delco :yesnod: :yesnod: :yesnod:
Old Oct 25, 2002 | 10:32 AM
-=Jeff=-'s Avatar
-=Jeff=-
Walbro makes most of them anyway.. I am pretty sure that Walbro makes the AC-Delco pumps..
Old Oct 25, 2002 | 08:06 PM
joesred84's Avatar
joesred84
Replace it with a Delco from an '85 and add a pulsator. Convert your fuel regulator to adjustable and set fuel pressure to 13 psi. If you don't want to go with the '85 pump I have a new Delco for an '84. New style vanes with electrical connector, just may have a "this week only special". Regardless what pump you use the electrical connector will have to be changed, GM changed all pumps built after '87. It's not a big deal. There are step by step instructions on CrossFire Injection Vault. Site is down now but should be back up early in the week. :yesnod:
Old Oct 30, 2002 | 05:11 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
Default Re: Which Fuel Pump??? (joesred84)
Walbro does not make the fuel pump for the C4 Corvette only the C5.
If you want a stock PnP replacement then a Walbro 190L/Hr pump will do just fine.
If you want something that will supply higher HP then a Racetronix + Walbro system woud be in order: http://www.racetronix.com/Racetronix-C43-FPK.html
Jack :cool:
Racetronix
Old Oct 30, 2002 | 05:35 AM
gtsyellow's Avatar
gtsyellow
Default Re: Which Fuel Pump??? (Racetronix)
tpis sells one that's larger than the stock one for those of us making 400hp or more, i've yet to install the one i ordered but it looks like a slightly larger version of a stock one.
To Which Fuel Pump???
