Sounds like your engine is now basically an LT4, the Hot Cam is bigger than the stock LT4 cam. The LT4 came with 28# injectors compared to the, I believe 22# in the LT1. If you're running stock injectors, that might be a starting point. Also look into getting a Dana 44 rear end, this was standard in the manual transmission cars, with the 3:45 rear gears. The automatics got the Dana 32 with I think 3:07? However, the Dana 44 will take bigger gears, like the 3:73 mentioned all the way up to 4:10.
I'm not sure, of course, if any of this has to do with it, but just some food for thought if you haven't already addressed it.
Hello, I own a 1992 C4 Corvette with an LT-1 and in my opinion my car is very slow. An average stock c4 corvette with an LT-1 runs a 13 -14 sec 1/4 mile pass.. on my particular vehicle I have made some mods. which are LT4 hot cam kit with heads, 58mm TB, edel brock manifold, hooker headers, borla exhaust, a slight bump up in stock compression, a cold air intake and some very beefy tires in the back, upgraded transsmission with shift kit, custom torque converter for 2500 RPM curve. Not sure what LB injectors I have and I run my 1/4mile no better than a 14 second pass. The take off feels great second gear kicks in with a alot of power but as soon as third gear kicks in my car boggs down.
Any sugesstion on to why my car runs like a stock anything i should check? maybe even a check list of things to check would be appreciated.
#TheGuyWithTheBlackVette
you say bogs down.
you mean kind of stutters under load in WOT?
optispark.
this happened on my 93 during drag runs when it had a bad oem optispark (due to water intrusion, cracked seals, and lack of a vent system - corrected on the 95-96 gen 2 models).
What was the DA during your races? And what was engine (coolant) temp? If known, what was launch weight?
My best pass at Englishtown was 13.017 sec @105mph with the DA at -1,100'. That's with a 2,000stall TC while making 300chp. On a tight track it pulled mid 1.8s short times.
That's damn good, E-Town used to be good from what my friends said. By the time I had everything sorted for a run they closed the strip. Sucks because it's a ~20minute drive from my garage lol.
There is a lot of good data here to check, let us know if you find anything.
Check fuel pressure, idle on up through the band, do it in the garage and then take it out with a gauge taped to the windshield on the street.
Check optispark out, get it on a dynojet with a WB and datalog. The curve and the scan data will indicate the problem. Could be the tune is way off base.
If cats are on the car and the previous two check, then I'd guess they are plugged up solid. That will kill the top end you should have now.
Its not the gearing or the tires or anything else, there is a bigger problem to solve.
