no acceleration after turns
Old Oct 27, 2002 | 11:02 AM
birdmandave's Avatar
birdmandave
1st Gear
Default no acceleration after turns
This might sound weird, with less then half a tank of fuel, after making a hard turn, either direction, my 84, will hesitate on acceleration. It's one of those it doesn't happen at mechanic problems. I put fuel additives in no change. has any had this problem?
Old Oct 28, 2002 | 07:11 PM
mn_vette's Avatar
mn_vette
Default Re: no acceleration after turns (birdmandave)
lets review our fizix. when you take a turn fast there is centrifical force pushing you to the outside of the turn. Your gas also feels this. If it slides too far the fuel pump won't have anything to pickup causing hesitation and a little stumble under hard acceleration.
In my gas tank there is a little tray in the bottom that the fuel pump sits in but it still has the same thing when it's around a quarter of a tank. Solution, redesign the gas tank, or just keep filling it up if you are planning on turning hard corners and accelerating :D
