94 6 speed low idle
It’s fine. There are no codes. The first thing I did was to remove the throttle body and clean it thoroughly with throttle body cleaner and a tooth brush. I had this issue on my 2003 Suburban and that solved the issue there. It didn't solve the issue on my corvette.What would you suggest? IAC issue? The second issue is that when I start the car I turn the key and it starts to crank then stops, nothing. I release the key and try it again and it starts right up. I have 120K on it.
Check for loose and cracked hoses around the engine, and test the EGR for proper function, a vacuum leak could cause the low idle issue/stalling. Be very careful with any plastic lines around the engine. They get brittle with heat and age, and will break easily from bending or pulling the plastic, only pull (gently!) by the rubber connectors.
The second issue, the starter cranks the engine then gives up? Does it only do this while hot? Is it a constant issue or intermittent?
