VATS testing woes...
So, I bought an 89 from an older gentleman who could not get it to start, actually I pretty much stole it. He did say it was at a shop during hurricane Matthew but the shop stated that the water level only reached the bottom of the doors (this was a lie of course as I am pretty sure the water reached the center console). Anyhow, everything electrical seems to work fine except for the power windows but I'll figure that out later. I have the typical VATS issue: I turn the key - nothing, I hear the starter enable relay click, no crank. Here is what I have done so far:
1. Bypassed the key using a resistor even though my key is reading correctly at the bottom of the column.
2. Bypassed the start enable relay (vatssucks.com)
3. I did notice that I cannot hear the fuel pump priming so I applied 12v to terminal G and the fuel pump runs.
4. Tried turning the key while I had 12v running the fuel pump and I still get nothing, no crank.
5. Attempted to remove the "bread box" (dumbest thing in GM design history by the way) to get to the VATS module. Finally was able to get the bread box out enough to get to the module but I do not know how to "test" the module.
6. I checked the battery and connections and all seem to be good. I even tested the fuel pump relay by the brake booster and it seems to be fine according to the testing methods found here in the forums.
I have not gotten under the car to try to jump across the starter to see if that works because even if I did, I still have no fuel. So, is there a way to test the VATS module itself, is there some other test I should be doing that I have not mentioned here? I do have plans to order an FSM but have not done so yet. I was hoping the experts here would have some tips for me.
And yes, I know I bought a car that had some water in it, but like I said, everything seems to work properly except for the starting issue. And besides, for $2500 (told ya I stole it), I bought it as a project and that seemed like a screaming deal. So if you have any tips, please let me know and I thank you in advance!
Chris
I don't believe that the fuel pump has anything to do w/VATS. On my '92, pump will prime even w/o a VATS resistor pellet confirmation. I think your problem is elsewhere. When the key is ON, what is the Security light doing?
All info I have found on here so far says that the ecm might not be receiving a signal from the vats module to prime the fuel pump to pressurize the fuel rail. I will try to get to the starter this upcoming week when I have some time off and see what I can find out there, thanks guys!
When ECM powers ON, the fuel pump runs for appx 2 seconds and stops. IF distributor reference pulses are then received by the ECM, the pump is turned back ON. Ie, when the engine is cranked, the pump turns back on.
The "15 minute wait" is actually FOUR minutes, but the FSMs suggest using 5 minute intervals for VATS checking. The fuel pump prime has nothing to do with the "VATS Wait".
