ZZ4 & SuperRam?????
Old Oct 27, 2002 | 09:44 PM
DaBo's Avatar
DaBo
Default ZZ4 & SuperRam?????
How much HP & TQ does the SuperRam with 58mm TB add to a ZZ4 crate motor.
I have visited many sites to get the answer to this question and have come up blank. I know that several here are running similar setups so I hope that you will share your experiance.
Thanks,
Old Oct 27, 2002 | 10:17 PM
needanother1's Avatar
needanother1
Default Re: ZZ4 & SuperRam????? (DaBo)
It might change the torque curve, but I doubt it would add any horsepower. Horsepower on a ZZ4 is pretty much limited by the flow of the D-port heads. If anything, I'd say the SR might limit hp a bit, vs. a 750 Holley. That's just my guess though. I don't have anything to back that up.
Old Oct 27, 2002 | 10:29 PM
ZD1's Avatar
ZD1
That is a very interesting question since the ZZ4 uses an updated aluiminum L98 head. (Updated in the since of seats/springs? but a bolt on replacement). This head as you well know flows 198 CFM at peak lift, but can be improved to 230/240 with a lot of effort/$$$ and the right know how (read lingenfelter $$). To that end any intake that bolt on will not improve the airflow...only take less away. I stole the following on intake flow, but keep in mind that the intake system is limited by the weakest link.
TPI = 198 CFM (go figure it matches the heads)
Accel TPI system = 232 CFM (probably good for TFS or edelbrock heads)
Accel SR = 240 CFM (Better CNC heads possibly AFR low buck heads)
MiniRam = I wish I knew...Possibly close to a single plane (Performer RPM 286/victo racer 275)
From the above you can see that the numbers are less than that of carb intakes, but would probably come close to the ZZ4's dual plane manifold - 350 depending on cam.
DOES any one know what the Miniram will flow?
Old Oct 27, 2002 | 11:18 PM
vader86's Avatar
vader86
What is the output of the ZZ4, what are the specs on its cam.
Old Oct 27, 2002 | 11:34 PM
DaBo's Avatar
DaBo
Default Re: ZZ4 & SuperRam????? (vader86)
The ZZ4 is rated at 355 HP and 405 TQ. It uses Aluminum heads with 58cc chambers, and 1.94 / 1.5 valves.
Cam specs are....Intake .474 lift, Exhaust .510
Duration @ .050 is Intake .208 degrees and Exhaust 221 degrees .
Old Oct 27, 2002 | 11:36 PM
vader86's Avatar
vader86
It would add about 30hp with the accel 219 cam, but with a small intake duration like that, i dont know exactly what it would give, maybe not much.
Old Oct 28, 2002 | 05:35 AM
gtsyellow's Avatar
gtsyellow
the 219 isn't really that much bigger than the zz4 cam, on the stock unported heads 30hp might be a bit of a stretch. the 219 has more intake duration but slightly less exhaust duration. i think the zz4 is a 208/22? lift is .488/.510.
Old Oct 28, 2002 | 01:22 PM
Raistlin's Avatar
Raistlin
Default Re: ZZ4 & SuperRam????? (gtsyellow)
i'm pretty sure the 219 also has .560 lift
Old Oct 28, 2002 | 02:20 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: ZZ4 & SuperRam????? (Raistlin)
560inch with 1.6 rockers 0.525inch with 1.5's
I would say the 219 is BIGGER than a zz4 cam,
Its about the same as the hotcam which could be 20 or more horses
:cheers:
To ZZ4 & SuperRam?????
