Braided brake line
I know that mechanics are trained not to let calipers hang by the hoses to prevent damage, but I've seen a car slide off a forklift in a junk yard in a way that one of the brake calipers hung on the tines of the fork lift, and the entire 4 door mid sized sedan was hanging by one of the brake hoses. Even stock "rubber hoses" are really, really, really tough.
You are correct, most people don't drive much on flat tires. One of the arguments of why braided stainless hoses are "better" for brake performance is often "race cars have braided stainless brake hoses." My point was that the main reason my race cars have braided steel hoses is because I want them for durability. Race cars are driven in conditions where most street cars would be parked. I want brake hoses on the race car that will get me back to the pits with a flat tire, even if I'm driving it around the rest of the lap at 60-80mph on the straights, with the shredded tire flapping around and tearing stuff up. I don't want the brake line to get torn even in those adverse circumstances. My choice of braided stainless isn't about "pedal feel," it's all about durability.
water is not any more compressible than brake fluid... both are considered incompressible as far as what little pressure brake systems are able to generate. I am sure you COULD measure the difference with some type of lab equipment, but it doesnt matter in this discussion because its not something a vehicles brake system would ever notice.
wet brake fluid lowers the boiling point of the fluid. When the fluid boils, it creates bubbles which are compressible... but the physical presence of water in the fluid does not cause the fluid itself to be any more compressible than if it was completely dry of water. As fluid ages its VERY easy to boil it as brakes under normal conditions can get into the 300-400 degree range pretty easily.
"feeling" a better brake pedal after a fluid flush is usually a placebo effect that in reality isnt there.
"Wet" brake fluid (brake fluid that has absorbed some moisture) is more compressible than "dry" brake fluid. After as little as 6 months, and certainly after a year or two, there is a noticeable softening of the brake pedal from moisture accumulation. After more than 2 years, it's quite significant. Again, this is most of what you feel when you "upgrade the brake hoses" to braided stainless.
They are schooled to hang it off a wire or at least that was what my shop class told us. That said, I have seen them hang it off the rotor or whatever surface they can. And if you believe it never falls, I have this bridge for sale. Just walking through the shop and glancing around, at least half of them do it.
Now that I own my own bleeder and have a compressor, it is definitely every 2 years at least. Bust my butt for a couple days to get everything done (5 vehicles, 2 ATVs, 2 motorcycles) within a day or two with time to do other stuff. Only reason I believe US and a couple other cars don't, especially cheaper cars is that they don't want to scare the owners into thinking maintenance has to be done.
Fair enough. So since I flush every couple of years like MB suggests, how long before I run out of life in the hose? I wish there was some way to tell since I don't have OE hoses anymore since I'd like to see if there is more pedal travel after 5 to 10 years of using the hose vs braided SS hose.
That said, I won't swear that it's the water itself that causes the longer pedal. What I can say with absolute certainty is that when I work on a higher mileage, older car with a less firm brake pedal, and I flush the system, the pedal gets more firm. There's something compressible in the system when the fluid is old and has discolored to the point where it's the color of Coca-Cola. It could be the water in the system, but it could also be some other by-product of aging and corrosion within the system.
As for "service life," my experience with standard (stock, rubber) brake hoses is that they last about 10 years before I find them stiff and/or cracking and needing replacement. Honestly, on the race cars, I don't think I've had any last as long as 10 years. Usually they get damaged before that point, or I've sold the car by that age. I will say that the service life of teflon hoses is not infinite, and I doubt the service life is any longer than standard (stock, rubber) hoses. I would also say that the teflon inner liner on the braided hose is what will eventually crack or harden and fail, and it's tougher to inspect that than it is to inspect a rubber hose which will likely form cracking on the outer surfaces as well as the inner.
IDK. Maybe I should just toss them at 10 years even if they are braided SS lines with teflon insides.
And I should be clear that I wasn't saying that there is no difference in "pedal feel" between braided stainless and stock brake hoses. I was saying that overall, for most people, the improvement from fresh fluid is far more significant than the minor change in pedal feel from braided stainless hoses.
Even the StopTch page that someone linked to above (http://www.stoptech.com/technical-su...rake-lines-q-a ) lists as the primary (meaning first listed) advantage "1. The SS braid provides superior protection from flying roadway debris. "
Personally, I wouldn't trust any flexible brake hose past 10 years, and I'd start inspecting closely at about 6 years, looking for cracks or a loss of flexibility. "crunchy" brake hoses are past their useful service life.
One more thing about braided stainless hoses, if the braided metal is exposed, you want to be certain that your retainers/hose holders are strong and well fixed to the hose and the body work or whatever. Braided stainless steel hoses are highly effective "files" or "saw blades." If they can move relative to whatever they are in direct contact with, they will file, grind and saw their way through almost any other material. Don't ask me how I know this.
