O2 sensor wire?
I believe the engine is from an '85 corvette and have been working to getting it running, installing the distributor, wiring, etc.
However, I cannot for the life of me find what would be the wire that goes to an O2 sensor (the car currently has headers that will need to be drilled for a bung).
Research has led me to believe it is a purple wire--but I can't find any thing of the sort.
I have found 2 wires on the drivers side that are cut/burnt--one is green with a white stripe (temp. sensor in the head?) and a black with brown stripe (no idea).
Can anyone explain or take a picture of where the O2 sensor wire originates from the loom on a '89?
you cant crimp or solder extension wires.you have to use posi-lock connectors and specific extension wire harness - if you need to repair them.
I had an idle rich condition on my 93, fhat i spent years trying to solve.
Only when i replaced the bosch o2’s with NOS acdelco o2’s and fixed the wiring (which had been extended due to long tube headers) did it fix the rich idle condition (and scantool indicated the bosch o2’s were working - so i believe the wiring (which had been soldered) wAs part of the culprit
i cant answer your question, but want to tell you those are very sensitive wires.
I assumed the wiring was from higher up in the engine bay.
When I looked at the smaller loom you pointed out, all of the wires looked dark. Everything was discolored and I pulled off some of the conduit--and there was the purple wire!
