EGR -code 32
Old Nov 16, 2018 | 09:30 AM
mavv72's Avatar
mavv72
7th Gear
Default EGR -code 32
Start with car runs great and only 60k on it. After 30 minutes or so the engine light comes on for a code 32.But this only happens on warm days. So I installed a new control valve relay and same thing. I drive this 1988 in the cool weather for days with no light. Just an annoyance,Anyone have ideas.
Old Nov 16, 2018 | 11:10 AM
3D-Aircrew's Avatar
3D-Aircrew
mavv72 - The factory service manuals have a section with troubleshooting charts for all the codes. Rather than guess and throw parts at it you should check out that section and see where it leads you. Something you can check though in the meantime is if all your vacuum connections are good. That can throw that code.
Good Luck,
Robert
Old Nov 16, 2018 | 08:16 PM
kittmaster's Avatar
kittmaster
Does it have an aftermarket exhaust? If so, the pressure drop causes the code to set.
Old Nov 16, 2018 | 08:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does it come on after steady driving (highway) for a while?
If so and you are running a stock TC, the ECM is calling for EGR and not seeing response from the indicator in the RH exhaust header.
I believe the test for this is to force EGR at idle and measure the indicator voltage, it should be zero volts.
Old Nov 17, 2018 | 09:03 AM
mavv72's Avatar
mavv72
7th Gear
Stock exhaust
Old Nov 17, 2018 | 09:04 AM
mavv72's Avatar
mavv72
7th Gear
yes comes on after steady driving for awhile
Old Nov 17, 2018 | 09:06 AM
mavv72's Avatar
mavv72
7th Gear
Good Luck,
Robert
yes I need to get one
Old Nov 18, 2018 | 08:28 AM
mavv72's Avatar
mavv72
7th Gear
Originally Posted by ihatebarkingdogs
I've been through this Code 32 on the highway thing on my 85, my 88, and a friend's 86. It was always the EGR Diagnostic Temp Switch had come out of calibration. Here's how I fixed them:
The engine and sensor must be cold. (Not driven yet that day).
Unplug the wire for the sensor that is in the EGR pipe at the rear of the engine.
Connect your VOM between the sensor wire and ground. It should be Infinite Ohms.
Twist the metal "terminal" in the center of the sensor clockwise, looking down on it. There may be some material locking the screw in place, but it should break away when you turn the screw.
When your VOM shows 0-Ohms, stop. Fine tune the adjustment for about 1/8th turn back from 0-Ohms.
---If you get the adjustment too tight, the sensor may be 0-ohms on a warm engine when you restart it. If the sensor is 0-Ohms at start up, the CEL will illuminate immediately, and Code 32 will set. (If you get a 32 on start up, the sensor is shorted, or "too tight").
Once you are satisfied with the adjustment, lock it with a dab of JB weld.
I will give it a try.thanks for the tip
To EGR -code 32
