2 issues....
Old Nov 19, 2018 | 03:00 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Default 2 issues....
1- whining sound coming from the back after few minutes of running the car and continues till the car is switched off.... Could it be the fuel pump?! How to make sure?
2- when idle, power drops, interior lights, cluster lights dims down and back up again plus the rpm also, feels like it will off then back again to normal idle!!
It’s 91, L98, Auto, stock... just had a rebuild last month (still breaking it in)
Old Nov 19, 2018 | 01:01 PM
ctmccloskey's Avatar
ctmccloskey
Have you checked out the operation of your charging system since the rebuild? How old is the battery? What is the voltage of the battery with nothing drawing power? With the car running what does the battery voltage show?
It could be a dirty or loose connection on the battery or your alternator could be suspect. Sometimes the problem can be caused by corrosion at the little post that supplies the Fusible Links with power. The post is behind the battery, it is attached to a frame rail and has a nut on it with several wires making connection. There is a battery Positive wire that comes back from the battery to supply the power. Each of the connections has a ring terminal and mine were copper or brass and had a ton of corrosion on them. After cleaning this post and all the ring terminals everything electrical was working with full battery voltage. Prior to cleaning the terminals my radio had 11 volts going into it, even the fuse panel gets corroded on these cars.
People used to put "Overdrive" pulleys on Corvettes trying to free up more power, the bad side is that they slow down the alternator and the water pump. A very bad idea on a C4 Corvette.
On the "whining sound", does your car have a power antenna? Is it working as it is supposed to? When they break you frequently get a constantly running antenna motor which makes a bunch of noise, especially at the rear near the drivers side of the car. If the fuel pump was making the noise it would be centered over the gasoline fill cap area.
A freshly rebuilt L98 sounds nice, Mine has 103,000 miles but the compression test showed the engine to be in great shape. These are great cars for cruising around in, I love cruising along at 60 mph getting 30 mpg from my C4 while listening to the CD player The one thing I did change is the radio. I removed the semi-functional Bose Gold Stereo and installed a new modern stereo that connects to my phone when I get into the car, well worth the effort and expense.
I hope that these suggestions might help you in finding the whining noise and solve the dimming problem!
Old Nov 19, 2018 | 01:15 PM
Kevova's Avatar
Kevova
Whining noise listening at fuel filler or under rear of car if noise is noticeable fuel pump or pulsator. Pulsator was initially were installed to reduce fuel pump noise. Later pumps were quieter so pulsators aren't necessary. If it original pump might be worthwhile to change it out I would also replace pulsator with a short piece of hose.
Charging System. Check connections, ground cable to block and to body grounds, positive connections at underhood junction block and fuse blocks. A charging system test would be in order. Typically not expensive, some auto parts stores do them for free.
Old Nov 19, 2018 | 04:34 PM
KyleF's Avatar
KyleF
Your fuel pump may be making noise because its pulling extra amps to keep up when the voltage drops.
Definitely seems like you have an alternator issue. You could have it tested just about anywhere.
Old Nov 19, 2018 | 11:56 PM
ZEROVETTE7's Avatar
ZEROVETTE7
Thanks all for the suggestions and feedback. Actually after the rebuild I was working on the car checking and cleaning and I forgot the key on “ON” position all night and in the morning the battery was dead “New one” I hook it up to CTEK5.0 and charged it full.
Its charhed and working fine now.
ill check the grounds and wiring as you mentioned as the previous owner did a lot of wires jumps and connection (can I use wd40 to clean theses connections?)
im slowly restoring all the old parts and replacing with new. Donno if the starter is the original or not I’ll check that.
As for the whining sound it’s constant all the time while running. Even when radio is off. I’m thinking of replacing the fuel pump anyway, you think it’s better to stick to original part or go for after market brand?
Im not really into electrical stuff so any advise on how to test the voltage/amps?
Thanks again appreciate the help
Old Nov 20, 2018 | 05:15 AM
GregMartin's Avatar
GregMartin
To check volts fist get yourself a multimeter. The cheap ones are generally ok these days but I have a Fluke which is a pretty good quality meter.
Ok to check volts ensure that the meter leads are plugged into the correct terminals on the meter. There is normally a common and two other terminals, one will be marked Volts and Ohms the other will be marked Amps. Plug one lead into the Volts/ohms terminal and the other into the common. Set the meter to DC volts and measure between whatever you want to measure and a ground connection.
You can do quite a lot of testing by measuring volts at various places. I would recommend that if you are not that familiar with electrical stuff that you do not attempt to measure current (amps). To measure current the meter needs to be connected in series (ie in line with whatever it is that you want to measure). The problem is that the meter needs the be wired into the circuit and the leads need to be connected to the Amp and common terminals of the meter. In this mode the meter has low internal resistance and if you try and measure volts with the leads in these terminals you will blow you the meter and posably injurie yourself.
Hooe this makes sense.
Old Nov 21, 2018 | 12:43 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Thanks for the advise ... I’ll see what I can do and update the findings ...
Old Nov 21, 2018 | 02:21 AM
GregMartin's Avatar
GregMartin
hi just reread my post lots of typos in there hopefully it made sense. If not just ask.
regards Greg
To 2 issues....
