changing fluids
Old Oct 29, 2002 | 07:35 AM
DRAZEN's Avatar
DRAZEN
Default changing fluids
Can anybody explain to me what is the best way to change all fluids in my C4, Lt1?
Where are the drain plugs?
Also, where are the knock sensors in the block?
Old Oct 29, 2002 | 08:23 AM
urtoslo's Avatar
urtoslo
Default Re: changing fluids (DRAZEN)
Wow, a Vette in Croatia! I saw C4 coupe in Ljubljana five years ago. Your's maybe?
The plugs are all under the car, pretty easy to find. You have to remove the rear differental cover to get that fluid out or suck it out the fill hole. No idea where the knock sensors are. Do you have a factory manual?
Andrej Balanc
Old Oct 29, 2002 | 09:52 AM
ittlfly's Avatar
ittlfly
The knock sensors are located midway on each side of the block just above the pan. They are covered by heat shields which are held on by 3 small nuts.
Good luck
[Modified by ittlfly, 5:52 AM 10/29/2002]
Old Oct 29, 2002 | 09:52 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Are you joking....I got the book on mine to see how....look on the owners manual....
Sorry for being so sharp...but...but...but??????????
How old are you????? :jester :jester :jester :jester :jester :jester
[Modified by oldace84, 8:54 PM 10/29/2002]
Old Oct 30, 2002 | 10:00 AM
DRAZEN's Avatar
DRAZEN
Default Re: changing fluids (urtoslo)
Thank you guys!
I'll try to find it!
To changing fluids
