84 C4 trans fluid change question
Old Nov 28, 2018 | 08:18 PM
theboss84's Avatar
theboss84
Default 84 C4 trans fluid change question
I am in the process of bringing back to life an 84 c4 that had sat for 9 years. I redid the fuel system as per advice from this forum, (85 fuel pump, pressure adjusted to 14lbs) and it now starts and runs great. Don't know how it drives out yet but it sure sounds good. I changed the oil and filter Saturday. My next project is to the drain the trans fluid and change the filter. I drained the fluid tonight and was happy to find no metal or signs of unusual wear. The fluid was of course dark red and had a funky odor but didn't smell burnt so I am going with the fluid and filter change only for now. I have done some research and looked here on old posts about what type of fluid to put back in the tranny but was unable to find what I felt to be the definitive answer. Since I am only doing a fluid change 4-5 quarts is what I am anticipating. The question is, do I use full synthetic or standard Dexron III? I have 5 quarts of each from prior projects so the cost factor is not an issue. Any advice would be greatly appreciated.
Old Nov 28, 2018 | 08:33 PM
theboss84's Avatar
theboss84
Thanks that's what I was thinking I just wanted some confirmation from you guys that know more about this than I do.
Old Nov 28, 2018 | 08:59 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by ihatebarkingdogs
Use the Dexron III. You may need 6 qts. It probably has Dexron in it now. Don't change its diet in old age.
Ha, that made me chuckle. But this is the correct advise.
Old Nov 29, 2018 | 12:40 PM
Kevova's Avatar
Kevova
There really isn't a set amount of fluid used to refill. Add 4 quarts, start engine and let idle, then add as necessary until full. Fluid needs to be hot (hot to the touch) to ensure it's full.
Add fluid.
Cycle shifter from park to low and back to park stopping in each position.
Recheck and repeat as necessary.
Stop adding when fluid is towards the bottom of the full hash marks.
Then take car for a spin 10-20 minutes and recheck add fluid to middle of "full" hash marks.
If you add to top of full hash marks before road test the fluid level could be off; low or over. As oil circuits refill/apply fluid level drops. The fluid expands when it gets hot leading to over full. The quick spin allows transmission to go through its operation and warm fluid to operating temp giving a reliable reading on dipstick.
383vett's Avatar
383vett
If you just drop the pan you will need at most 4 quarts. I have left my tranny dripping for over a month and was able to get almost 2 quarts extra because the converter slowly bleeds some fluid out.
Old Dec 1, 2018 | 11:25 PM
aklim's Avatar
aklim
My understanding is that you can go up but not down. You can use say Dextron 6 in a Dextron 3 trans but not the other way. You could also consider using a flush machine to get rid of as much fluid as you can. I really wouldn't worry about using synthetic. I've run synthetic in older cars but not experienced problems unless the car is on the way out in which case, no fluid will fix worn out parts.
To 84 C4 trans fluid change question
