Any aftermarket shift knobs available for ZF6?
Oct 29, 2002 | 11:15 AM
Any aftermarket shift ***** available for ZF6?
90 ZF6. I want to replace my shift **** due to a little wear, any suggestions?
Oct 29, 2002 | 11:37 AM
Re: Any aftermarket shift ***** available for ZF6? (AS84)
Oct 29, 2002 | 01:56 PM
Callaway offers an expensive one. Go to their website.
http://www.callawaycars.com
Phil
[Modified by wheelsup, 11:57 AM 10/29/2002]
Oct 29, 2002 | 02:12 PM
Re: Any aftermarket shift ***** available for ZF6? (wheelsup)
From what I was told, any shifter **** that is advertised for the C5 6spd will work on the C4. I know most of the catalog companies list several for the C5.
Oct 29, 2002 | 02:14 PM
thanks guys, MAD has a couple for 40 bucks...but I'm not sure how the reverse lock out works...anybody have any ideas
Oct 29, 2002 | 03:17 PM
I think the reverse lock out is a separate from the shift ****. I don't think it makes any difference.
Oct 29, 2002 | 03:24 PM
I believe Corvette Central has them for under $59 ... which is the cheapest price I have found.
Brian
Oct 29, 2002 | 04:56 PM
Re: Any aftermarket shift ***** available for ZF6? (HTRK-1)
That is correct
here is my reverse lock out shifter with a Flame Ball
Oct 29, 2002 | 05:21 PM
Cruise-In V Veteran
Cruise-In VI Veteran
Just about any ball will fit on there. I think that MAD and Eckler's sell repro's too! I have the silver ball made for the C5. I like it a lot, but have to cover it up if it's out in the sun....that baby gets real hot if not! :D
Oct 29, 2002 | 06:41 PM
MoMo... but make sure you have a short shifter otherwise your knuckles will hit the radio in 3rd.
[Modified by rcolling, 2:42 PM 10/29/2002]
[Modified by rcolling, 2:43 PM 10/29/2002]
Oct 29, 2002 | 07:25 PM
From: ...tearing up the highways, one state at a time™®©
Re: Any aftermarket shift ***** available for ZF6? (rcolling)
My wife bought me a Black CALLAWAY shift **** for my 89 zf6. I like the feel however, I use one of my little daughters socks as it gets cold in winter & hot in summer :D $65.00 at
Oct 29, 2002 | 08:52 PM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Re: Any aftermarket shift ***** available for ZF6? (Scoob)
That's what I have
Oct 29, 2002 | 10:57 PM
Re: Any aftermarket shift ***** available for ZF6? (Mr Mojo)
All Momo's fit, here's mine
Oct 29, 2002 | 11:36 PM
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Re: Any aftermarket shift ***** available for ZF6? (Hammer)
I had the ****
Hardbar sells
www.hardbar.net
I like t-handles better.
Now I have a B&M Hammer Shifter.
Chris had to custom machine it to fit though when I order the Hurst Shifter.
Oct 30, 2002 | 12:50 AM
Re: Any aftermarket shift ***** available for ZF6? (BrianCunningham)
www.flameball.com You can hook them up to light up when you turn your lights on....Pretty Damn :cool: and it gets looks of lookers :lol:
Oct 30, 2002 | 01:29 AM
Re: Any aftermarket shift ***** available for ZF6? (-=Jeff=-)
That is correct
I take it with your reverse lock out your Flame Ball isn't lit? This is the only thing holding me back at the momemt. (besides the cash :D )
Oct 30, 2002 | 02:48 AM
Re: Any aftermarket shift ***** available for ZF6? (R94 LT 1)
tired a few MOMO ones.IMO , I dont think any **** looks as good as the stock one. :cheers:
Oct 30, 2002 | 02:55 AM
Re: Any aftermarket shift ***** available for ZF6? (RED92LT1)
Brian
I just ordered a repro **** and insert from the Last Detail for $59 for my 89 ZF6 after failing inspection for not having the pattern on the ****.
Oct 30, 2002 | 09:22 AM
Call me rice, but I've been eyeing a MoMo one. Anyone know where I can get a good price on their *****?
Oct 30, 2002 | 09:31 AM
You are correct, currently it is unwired. I did have it wired last year but there is no good way to run the wire tight against the shifter.
I am swapping to a Hurst Shifter in the Spring when my new clutch goes in, so it won't be a problem then.
