1995 Bose Radio issue
Old Dec 3, 2018 | 08:48 PM
dab1600620's Avatar
dab1600620
4th Gear
Default 1995 Bose Radio issue
All speakers cut out and antenna retracts. Clock still works as do the station presets. After shutting radio off for a while, everything works again when it is turned back on. What should I look at first?
Old Dec 3, 2018 | 09:10 PM
s carter's Avatar
s carter
Start simple reseat all the plugs on the Radio tuner behind the right seat in the storage hatch. If no improvement pull the Radio head in the dash do the same, make sure the fuses are seated well enough.somewhere your losing power and I'm thinking it's the ignition hot, your keeping your memory but the Radio thinks the car is turned off.
Old Dec 3, 2018 | 11:28 PM
Kevova's Avatar
Kevova
Bose system is a component radio. Control head is in dash and receiver is under fabric liner in right storage compartment. FSM or pages related to radio would be handy. Dealer should be able to tell if there is a local GM - Delco electronics service center.
Old Dec 16, 2018 | 12:27 AM
dab1600620's Avatar
dab1600620
4th Gear
Thanks, I will try to check the connections next weekend.
To 1995 Bose Radio issue
