Strange clicking noise from around plenum area?
Old Oct 29, 2002 | 01:10 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Strange clicking noise from around plenum area?
Ever since I came back from the track Saturday I have this clicking noise that seams like its coming from the area around the intake. It almost sounds like a relay clicking on and off repeatedly. I figured that maybe the EGR valve is the culprit so I unplugged the vacuum line going to it and still the noise is there. Any ideas :confused:
Old Oct 29, 2002 | 01:15 PM
sunrise.cm's Avatar
sunrise.cm
Default Re: Strange clicking noise from around plenum area? (NUckINg FuTS)
Injector(s)? They are solonoids and can be noisy. How is your idle?
Old Oct 29, 2002 | 01:24 PM
KYVette90's Avatar
KYVette90
If it only started doing it after you ran it at the track it could be a colapsed lifter, a bent push rod a bearing going out or even the injectors. Also a vaccum leak on the intake or plenum can sound like a ticking noise.
Old Oct 29, 2002 | 02:12 PM
MrNuke's Avatar
MrNuke
Default Re: Strange clicking noise from around plenum area? (KYVette90)
How frequent is the noise? I mean does it speed up if you rev the engine? Is it intermittent? If it only started after a race, I'd say check your rockers/pushrods, and possibly lifters..
Old Oct 29, 2002 | 02:48 PM
NUckINg FuTS
Default Re: Strange clicking noise from around plenum area? (MrNuke)
The noise is not that frequent. It comes and goes. Its definitely intermittent. The noise is to loud to be an injector. i can literally hear it with the hood down and in the drivers seat? :confused:
Old Oct 29, 2002 | 02:52 PM
vettmech's Avatar
vettmech
I think I'd pull the valve covers and look in there first :seeya
Old Oct 30, 2002 | 12:08 PM
sunrise.cm's Avatar
sunrise.cm
I had an injector that I could hear in the drivers seat with hood closed. Don't think I heard it outside with hood closed. Was abe to hear it with hood open on passenger side. Also can be intermittent. If it is not an injector, my next thought is, as mentioned previously, valve cover time. Lifter would be my next guess. Intermittent liffter?? I have not seen one. Good luck
Old Oct 30, 2002 | 12:17 PM
vettmech's Avatar
vettmech
Default Re: Strange clicking noise from around plenum area? (sunrise.cm)
If it's a flat tappet can lifters can definately come and go. Also some engines have valve rotators that come and go........... I've even had stock type rockers do that .........when they are worn :seeya
To Strange clicking noise from around plenum area?
