Electric water pump-Any HP gains for the LT1 -Pros vs Cons?
Received 1,407 Likes
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (Quick1)
since the water pump is cam-driven on LT's, you might as well go electric
Meziere seems to be popular
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (vader86)
St. Jude Donor '04 & '05
Can you install an electric pump on an '84 vette?????
thanks
:D :D :D :D
thanks
:D :D :D :D
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (oldace84)
You can easily notice how an LT1 will revv easier from idle with the mezzziere. top end accelerates quicker too... the redline hits much faster. Add pullies as well and you have an LT1 that has virtually no drag from accessories.
No dyno, but everyone familiar with LT1 that has driven/sat in it has said "What did you do to this car?!?" Seems to run much smoother. After I installed it, my wife drove it about 100' (she has a great butt-o-meter) and said "What did you do to the car".
Addtional PRO - car runs 10 degrees cooler in normal operation. In another post someone did some calculations that the HD Meziere pumped the same volume of water as the stock pump at 4K RPM. If you spend a lot of time above 4K you will probably need a bigger radiator as even the stock pump is cavatating badly. Cruizing across the desert at 120MPH the temps held at 224.
Other PROs - you can run the coolant while the engine is off, if you add a switch to the fans you can drop the engine temp really quickly.
You can purge air out of the system without running the engine.
[Modified by John Row, 2:58 PM 10/30/2002]
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (John Row)
my car has a 160 thermostat... but i havnt changed the chip so the fans coem on early. with the mezziere even on a warm day with a lot of idling it wont go over 188'f. While driving its usually around 177. nice and cold
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (388 SOLid RoLLeR)
Does the LT1 and LT4 have the same water pump? I am considering doing this to my car since I have about 60,000 on my current water pump.
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (CowboyNVette)
Plus:
Cools faster as it flows more coolant
Doesn't sap the engine of power through having the motor power the pump
Minus
More to go wrong(my experience is that electronics fail much sooner than mechanical devices, especially aftermarket)
High cost($300 hp for 5-10hp)
weighs more
I would stick with mechanical on a daily driver and consider the electric for a weekend warrior.
Minus
weighs more
Re: Electric water pump-Any HP gains for the LT1 -Pros vs Cons? (92TripleBlack)
Plus:
Minus
weighs more
Minus
weighs more
The biggest drawback I can see out of the whole Meziere situation is that nobody has made a camber brace that will clear it, so that kinda sucks. I've been using mine as a daily driver for about 10,000 miles so far and haven't had the first problem out of it, that doesn't mean I never will, but I think it's worth it. If it died today I'd replace it with another one, it just makes life so much easier when trying to flush / purge the cooling system.
For whoever asked, yes the LT4 uses the same pump as the LT1, so you can use the Meziere.
