Engine turns over but won't start
Old Dec 19, 2018 | 08:55 PM
remun's Avatar
remun
5th Gear
Default Engine turns over but won't start
I bought my grandson an 85 coupe about 6 months ago. he has driven it around 1000 miles. He drove it to college one morning, again at lunch, and after class he tried to start it. It will spin over but not getting any spark. Also noticed that the speedometer and tach had stopped lighting up when the key was turned on. We replaced the coil, dist. cap, and rotor. Still no spark. Can anyone give me any advice on what to check next? Thanks.
Old Dec 19, 2018 | 09:15 PM
xrav22's Avatar
xrav22
When you replace the pieces, you need to do the ignition control module(ICM) also. It is the thing under the rotor. As for the dash, you can tru to tap it from the side, and see if it lights up.
Bulbs may have went out. Make sure grounds are clean , for sure next to the battery and above oil filter.
Good Luck.
Old Dec 19, 2018 | 11:56 PM
remun's Avatar
remun
5th Gear
Thanks, I'll order a new ICM
Old Dec 20, 2018 | 10:42 AM
xrav22's Avatar
xrav22
Here is a tip, you are supposed to put thermal paste( like you do when installing a cpu in a computer) under the ICM make sure it is very clean and put a thin layer(like a cpu).
I am using a standard motor product one from rock auto. Take a pic of the wires and make sure they are on all the way. Check your oil pressure and fuel senders to make sure the wires are hooked up while you
have the rotor off. Other than distributor turned to far(not tight enough) or a wire fell off the distibutor , it should run.
Old Dec 20, 2018 | 11:36 AM
ctmccloskey's Avatar
ctmccloskey
I would use an alcohol pad to wipe clean the surface before putting the thermal transfer paste on the distributor. It is what you do on a CPU as well, cleanliness is important to the lifespan of the ICM.
Merry Christmas and may you have a wonderful New Year full of great "Corvette experiences"!
Old Dec 20, 2018 | 12:07 PM
s carter's Avatar
s carter
All advise is pretty spot on but with a basic test light check the Hot lead going to coil make sure 12 Volts is there. also try Starting with Tach not connected just in case it's grounding out.
Just as a to confirm that all that was replaced is correct, when you replaced the Cap did you bring over the Ground Bridge from old cap if new one didn't already have one. I have seen some fairly experienced people totally forget it and scratch their heads for it.
To Engine turns over but won't start
