Clutch won’t disengage even after a new one installed.
I’ve bled for days every way read every text and seen every video, stil not enough pressure to disengage at all, with car on or off. Does this pivot ball and fork look damaged? Cause that cause my issue? It has lots of play in it. I’ve installed new clutch kit from valeo/Sachs with throw out bearing and same issue.
1987 c4 4+3
1987 c4 4+3
1987 c4 4+3
1987 c4 4+3
Did the new parts match the old? Check for a crack in the fork right over the pivit ball. Good Luck!
