Jacking up vette????
Old Oct 30, 2002 | 02:13 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Jacking up vette????
Where are the best points to jack up the vette???
FRONT???
REAR???
HELP...
THANKS
tony :eek: :confused: :eek:
Old Oct 30, 2002 | 12:03 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Jacking up vette???? (oldace84)
Two on each side - 1 behind the front wheel well and 2 in front of the rear wheel well. Jacking points should be marked by a "\/ Place Jack here \/".
Old Oct 30, 2002 | 12:20 PM
vettmech's Avatar
vettmech
Default Re: Jacking up vette???? (Steel Blue 91)
Yup they are marked. When I do my oil changes at HOME I use a floor jack under the left rear one and pick it up until the front wheel clears the ground. It gives plenty of room to get under for an oil change.......... don't know what you're up to but hope that helps......... OH and my hood clears the garage door even opened when I do this :seeya
Old Oct 30, 2002 | 04:05 PM
John Row's Avatar
John Row
Default Re: Jacking up vette???? (vettmech)
... I use a floor jack under the left rear one and pick it up until the front wheel clears the ground. It gives plenty of room to get under for an oil change
:eek: I hope you use a jackstand somewhere there.
Old Oct 31, 2002 | 09:08 AM
vettmech's Avatar
vettmech
Default Re: Jacking up vette???? (John Row)
Oh I forgot to mention that ........yes I would NEVER get under a car without a jackstand........teacher has to set an example ya know....... in fact there's enough room when I raise my car that a jackstand will go in there too................ NEXT to the jack but I don't put the car ON the stand here .......... it's just in case the jack fails :seeya
Old Oct 31, 2002 | 11:32 AM
quiksilver458's Avatar
quiksilver458
i roll my car down to end of driveway and park it in the little dip right before road.. slide right under car... :)
Old Oct 31, 2002 | 03:09 PM
vetracer's Avatar
vetracer
I do a lot of work under my 2 corvettes and fabricated a piece that slips into the floor jack that replaces the standard lift pad. It fits between the two exhaust pipes and contacts the differential. This way I can jack the rear, put the jackstands in place, put the regular pad back in place, then jack the front under the front crossmember. This works easiest for me.
Old Oct 31, 2002 | 03:10 PM
scorp508's Avatar
scorp508
There used to be a unit called the "Vette Buddy" that did exactly this. I need to make my own up.
Old Oct 31, 2002 | 03:57 PM
JonM's Avatar
JonM
Default Re: (scorp508)
http://www.corvettecentral.com
part # 104605 49.95
Old Oct 31, 2002 | 03:58 PM
vetracer's Avatar
vetracer
BTW Scorp, while we are on the subject of 'vettes on jacks, have you started your ZF conversion yet? I did mine a year ago and was wondering how yours was going.
Old Nov 1, 2002 | 08:09 AM
Rkreigh's Avatar
Rkreigh
Default Re: (vetracer)
I know this sounds crazy but a buddy of mine showed me a tip.
he just puts a flat piece of 3/4" plywood on the jack and jacks up the rear of the car on the exh pipes. I thought it would dent them up and crush everything but it distributes the load and works OK. I got brave and tried this and it worked ok for me too. the jack a buddy would be better though.
I like the rear end jacking method. I also bought a set of the Rhino plastic ramps but even then I need a 2X4 to get the front spoiler up a bit.
these cars are pretty low!!!
Old Nov 2, 2002 | 08:07 AM
madquake's Avatar
madquake
Well this is not for everybody ...
But I just tell my wife to lift the car from the fender and hold it there till
my work is done...
Sometimes she gets tired ... So I Cheer her on!!
You can do it Sweety .. one more minute honey almost done!!
:lol:
Old Nov 2, 2002 | 06:13 PM
black bart's Avatar
black bart
Default Re: Jacking up vette???? (vetracer)
:yesnod: :yesnod: Thats how I do it also. :yesnod: :yesnod:
To Jacking up vette????
