Valve cover question
Old Dec 29, 2018 | 08:17 PM
85 CRVET's Avatar
85 CRVET
Default Valve cover question
Hi, I got some proform chrome Chevrolet valve covers to install on my 85 and I had a question about the pcv part. I’m probably going to install them while I put an air pump delete on it and I was wondering if it would be good to replace the pcv lines and plug them and get oil breathing filtered baffles instead. I thought that would look better like that but if it would cause problems I just won’t do it. I’ve heard some people say that’s fine and some say it can put oil on the engine and cause idle problems.
Old Dec 30, 2018 | 11:04 AM
Kevova's Avatar
Kevova
You need to keep the pcv. If not crankcase pressure will build and cause leaks. The oil vapors filling engine compartment can cause other problems.
Old Dec 30, 2018 | 11:19 AM
aklim's Avatar
aklim
It could cause idle and running problems if you did one side. So if you remove the PCV, you have to remove other breather that pushes air into the crankcase. So vent both or not at all. I have my PCV on the Powerstroke vented to the ground instead of the intake track which will send it all over the intercooler and pipes.
Old Dec 30, 2018 | 02:27 PM
85 CRVET's Avatar
85 CRVET
Ok, well I guess I will just keep the pcv then. I thought it would look neat with a chrome filtered baffle but I’ll just put the hoses on the new covers when I go to install them. Thanks for the answers.
To Valve cover question
