Auto shift cable help
Old Dec 31, 2018 | 08:12 PM
BLKMAMBA's Avatar
BLKMAMBA
Default Auto shift cable help
Okay so I made a post somewhere else before and got some conflicting info. I have a 93 auto. I need to replace the shift cable. at 1st attempt using info. from another source that said I did not need to remove the side of the center console for access to the through floor plate to remove old cable. I removed radio and shifter bezel only to find there is no access to that through floor bracket. it was solid plastic and below that was BCM. so I apparently must remove side of console. what is the process for this? I am told screws are under glued carpet. if you have done this and can pass on some info. it will be greatly appreciated. PS I do also need to remove my instrument cluster to replace LCD power plug. I saw a video a guy said you need to lower steering column to get cluster out? true?
