I have decided to go with a 50/50 mix on coolant as I am changing the radiator. Can anyone tell me how much coolant the entire system takes on my 95 c4? I am draining the entire block and cooling system and is there a best way to prime the system as there is no radiator cap. Just the radiator resivore and over flow plastic tank. Thanks
Watched the video, if you want generic information on cooling systems it's ok, but to title it as "Coolant Flush How-to: Chevrolet Corvette (1990-1996)" is wrong.
At no time is a C4 corvette seen. There is a C5, along with a Buick, Honda Civic (maybe), and a Camaro. Misses all the details you need like knock sensors and purge valve locations,
There IS a "radiator" cap; it's on the surge tank on the passenger's side of the car by the firewall.
Remove that pressure cap, fill the system until it's full to the neck of the black tank (and stay's full)
Open the two bleeder screws, one at a time until you get coolant out of them; then close 'em up.
Top the black surge tank to the neck again, then fill the white/translucent overflow than that's under the right headlight to the proper, "cold" level. Install both caps....you're done.
This makes the "50/50" part easy;
For $10, I suggest you replace the thermostat also.
When your radiator work is done and the block drains are buttoned up, add coolant to the system through the black surge tank -- it should take about 3 gallons off the bat. Run the engine until the thermostat opens -- the level will drop and coolant is seen swirling and flowing. Top off the black surge tank until it takes no more, install the cap and shut off the engine. Fill the white overflow to slightly above the cold mark. After a few heat cycles, check the white overflow and add coolant as needed.
The LT1 and LT4 cooling systems are self-purging. Since the black surge tank is the highest point in the system, that is where any air will collect. When the engine cools down, coolant is pulled from the white overflow, as needed. So the system automatically keeps itself full as long as there is coolant in the white overflow. You should not need to remove the radiator cap again (from the black surge tank) until the next service.
Don't forget to take out the knock sensors and do some searching on this site before you start. There are TONS of posts about this and several good YouTube videos as well. I recently did mine and also replaced the thermostat and hoses.
I filled the radiator as much as I could with the car off and then turned the car on. Once the thermostat opened, I filled until it started bubbling back out of the upper reservoir. I put the cap on, shut the car off and let the air out of the bleeder screw. I had to let air out of the bleeder screw a few more times over the the next couple days and add a little more coolant before my "Low Coolant" light would go out.
If you followed the simple process that I described above, you'd have finished in minutes rather than days. FYI for next time.
Lol,I actually started out that way, but couldn't get it to fill all the way. I had to try it other ways. Nothing about my crank seal replacement, oil pan replacement and WP replacement went the way I read that it should. Turned out well in the end though.
