1985 corvette fuel pump
Old Jan 9, 2019 | 12:35 AM
Mason123's Avatar
Mason123
Default 1985 corvette fuel pump
is it possible to do yourself? And how
Old Jan 9, 2019 | 07:24 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Should take you less than an hour. To be "safe" consider cleaning the fuel gauge contacts points when it is apart.
Old Jan 10, 2019 | 02:51 AM
jseremba's Avatar
jseremba
Pretty easy job.
Remove the fuel door by loosening some torx, disconnect the hoses and the wire plug, loosen the bolts. Pull oput old and install new in reverse order . Enjoy
Old Jan 10, 2019 | 10:58 PM
aklim's Avatar
aklim
Nope. You and a pitcher of Long Island Iced Teas should make it better.
Seriously, it is so easy if you get a kit from Racetronix. It will have a gasket and the SS bolts instead of the old rusted ones.
To 1985 corvette fuel pump
