Wiper issue
Old Jan 13, 2019 | 09:27 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Wiper issue
1996 CE wipers do not shut off with switch. Turn on fine. Would it be the mechanism in the stalk? Does the whole stalk need to be replaced? Could it be wiring? Have not taken anything apart yet. Thanks.
Old Jan 15, 2019 | 01:39 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
1st place I would check would be the connections at the motor under the hood. With the wipers running in the off position move the connectors and see if that causes anything. I would also check the motor contact as they are a high wear item. Not sure where the column switch connects but I think before I tore it apart I would connect a known good switch as a test. Sorry I wasn't more help.
Joe K
