1989 6 speed
Old Jan 16, 2019 | 02:28 PM
BillDurant's Avatar
BillDurant
Default 1989 6 speed
Seems I have to get starter rebuilt or buy new
saw 2 video’s on line. One aays exaust hast be lowered to get starter out. Other says it wiill come out not lowering exaust.
Any one in here done this before?
thanks
Old Jan 16, 2019 | 03:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Is the procedure shown/explained in your FSM?
Old Jan 16, 2019 | 04:13 PM
BillDurant's Avatar
BillDurant
don't have one just asking if anyone had done this before
Old Jan 16, 2019 | 07:29 PM
NavAir's Avatar
NavAir
I've replaced the starter on my '89, did not have to lower exhaust. Standard starter, standard exhaust. It is a tight fit, but you can do it. I didn't even have a lift then, just jacked up that side of the car...
Old Jan 18, 2019 | 03:30 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Starter swap on my 89 ZF6 was easy peezy! No exhaust moves required!
Old Jan 18, 2019 | 03:34 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
just drop battery before disconnecting the wires
Old Jan 18, 2019 | 04:03 PM
vader86's Avatar
vader86
Might be easier if you dropped the exhaust but not a necessity.
Certainly if anyone is doing headers, its best to do the starter at the same time.
Old Jan 18, 2019 | 05:13 PM
dc6902's Avatar
dc6902
No problems removing.disconnect battery.
Old Jan 19, 2019 | 09:20 AM
BillDurant's Avatar
BillDurant
Greg
what kind of starter did you buy ? I have the OEM part number GM 10455709 > this is what Rock Auto says
https://www.rockauto.com/en/moreinfo.php?pk=6804144&cc=1041242&jsn=4 99
and did you replace the solenoid too ?
Old Jan 19, 2019 | 03:47 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by BillDurant
Greg
The starter was my very first "service". I bought my 89 in 99 and had to replace it during the first year/two. It only had 15-20k miles at that time. I bought a starter from O'Reillys. I've no doubt suppliers/brands could have changed by now. I do remember how easy it was (considering it was the first part replacement on ANY Corvette!). I was done in half and hour. I will have owned my 89 for 20 years in about 2 weeks!!!
If the solonoid didn't come with (bolted to) the starter, I didn't buy one separately. IIRC, the well-documented problem with starters isn't normally the solonoid. If it were, that's all people would be replacing. Conversely, one/two have rebuilt the starter to repair.
To 1989 6 speed
