Where to find heated O2-sensor?
Old Oct 31, 2002 | 07:44 AM
dahlman's Avatar
dahlman
Default Where to find heated O2-sensor?
Hi!
Anybody knows where i can buy a heated O2 sensor for
my Corvette 1990 (L98)?
Is there any specifik item you can recommend ?
Old Oct 31, 2002 | 08:10 AM
chucks88's Avatar
chucks88
Default Re: Where to find heated O2-sensor? (dahlman)
Follow your drivers side exhaust manifold down to where it connects to your Y-pipe. And there it should be screwed into your Y-pipe. I kinda looks like a spark plug with a wire attached to the top of it. To change it, I had to jack up the driveres side. Special sockets can be picked up from your local auto parts store which allow for removal of the sensor with the wire on it. I however was able to R&R it with an opened end wrench 13/16's I believe.
Old Oct 31, 2002 | 08:21 AM
Jimbo93's Avatar
Jimbo93
Default Re: Where to find heated O2-sensor? (chucks88)
I think the question is where to buy one, not how to remove one
Old Oct 31, 2002 | 08:29 AM
dahlman's Avatar
dahlman
Default Re: Where to find heated O2-sensor? (Jim Holbrook)
That's correct Jimbo. :)
Old Oct 31, 2002 | 08:45 AM
chucks88's Avatar
chucks88
It sure does. Maybe I should wait until I at least finish my firtst cup of coffee before I start sharing my expertise with you common folk :lol:
Old Oct 31, 2002 | 10:07 AM
Steel Blue 91's Avatar
Steel Blue 91
There are two things I won't touch without a full load of caffeine, computers and vetts. :lol: :lol: :lol:
Old Oct 31, 2002 | 10:36 AM
Nathan Plemons's Avatar
Nathan Plemons
I would talk to our good friend Jeff Kopp. I've asked him this same question because I need to convert mine to heated sensors. Now I have to buy 2, so it kinda sucks. He can get the sensors, P/N 25312179 and a handy wiring "repair connector" for iti, P/N 12126012
The repair connector is essentially the wiring harness end of the O2 sensor plug with wires coming out of it. This way you can splice this into your wiring harness signal wire and then run your own wires for the heater, and you're done. If you ever have to change the O2 sensors again you don't have to splice anything, you just plug it in and go.
:cheers:
Old Oct 31, 2002 | 12:07 PM
Jim85IROC's Avatar
Jim85IROC
Default Re: Where to find heated O2-sensor? (Nathan Plemons)
I don't have part numbers, but when I went to the dealer I asked for one for a 90 ZR1. They had it in stock and it was about $65 or $75. Since there has never been a ZR1 driven through my town, let alone one sold at their dealer, I'm under the impression that it's a common part. :) It was a 3 wire sensor. I bought the matching harness plug and pins from a local Big A auto parts store. I wired it to get power from my fuel pump relay, and to ground on the bracket that holds that relay. This gave me very neat, clean wiring all in one location.
Old Oct 31, 2002 | 10:25 PM
dlmeyers's Avatar
dlmeyers
Default Re: Where to find heated O2-sensor? (Jim85IROC)
Some O2 sensor wire trivia.
Three wire units:
1-O2 Voltage sensor wire
2-Power wire for the heater
3-Heater Ground
Guess the reason for more expense is more wires.
dlmeyers 90 coupe zf6 3 speed shocks
Old Nov 1, 2002 | 02:47 AM
vettl83's Avatar
vettl83
Yep your right Jim the ZR-1's have three wire heated sensors two of them. You can get the Bosch ones at Auto Zone for around 35.00 each. 84 CF 91 ZR-1
Old Nov 14, 2002 | 12:07 AM
keekster's Avatar
keekster
where is everyone running the hot lead to ?
Old Nov 14, 2002 | 12:31 AM
Nathan Plemons
Default Re: Where to find heated O2-sensor? (keekster)
I will be running mine to the 12v+ distribution block located just behind the battery. It will be fused and have it's own relay. I was going to activate my relay using the same signal that gets my water pump, it's hot in the run position. That would work, but Jeff Kopp suggested that I get it from the fuel pump relay, that way it will only be on when the engine is running.
To Where to find heated O2-sensor?
