C4 brake booster failure
Old Oct 31, 2002 | 08:29 AM
COMPVET's Avatar
COMPVET
Default C4 brake booster failure
I can't seem to be able to order a diaghram rebuild kit for a buddy's '87. I had gotten them from GM in the past but my dealer says the are no longer available, is he just having a bad brain day or what? Anyone have a part number that may still be good?
Also does anyone have any idea why these things are failing? Untill the C4 a booster failure was about the rarest thing on the planet.
Thanks guys
Pete
Old Oct 31, 2002 | 09:57 AM
vettmech's Avatar
vettmech
Default Re: C4 brake booster failure (COMPVET)
you might want to try the last detail ........ they seem to have stuff that's no longer available :seeya
Old Oct 31, 2002 | 12:29 PM
PTz-92-LT1's Avatar
PTz-92-LT1
If you are technical enough to rebuild the booster you will understand that the two most common causes for failure are a leaking master cylinder and dirty air. Check these areas.
To C4 brake booster failure
