Header spark plugs - Any recomendations?
Old Jan 22, 2019 | 01:21 PM
corvetteracer72's Avatar
corvetteracer72
Default Header spark plugs - Any recomendations?
Hi guys ,
I have a pair of Hedman headers installed on my 85 . They went in pretty well, but there in an issue with the close gap between the spark plug and the wrapped header .
Recently seen some sparks ( arcing ) between the spark plug cap and cylinder . To me , the only solution seems to be a shorter spark plug and a better insulated spark plug wire set.
I've bought a set of new wires from Zip and those aren't much improvement over the old ones I had .
Is there someone who is using such short spark plugs ?
Any recommendations ? PN# 's ?
Thanks !!!
Old Jan 22, 2019 | 02:37 PM
Mjet67's Avatar
Mjet67
I have the Accel header spark plugs, part # 8199, in my 89 with Hedman Elite's
Also have insulating sleeve over each of the spark plug boots.
Old Jan 22, 2019 | 03:10 PM
corvetteracer72
Do these Accels also work for the iron heads on my 85 ? Sorry for the dumb question ....
Seen on Summit Racing that they are listed only for 86/87.
Old Jan 22, 2019 | 05:06 PM
corvettenorway's Avatar
corvettenorway
CHAMPION SPARK PLUG RV92YC 930 and https://www.ebay.com/itm/DRAG-RACE-S...d=231296580012
Old Jan 22, 2019 | 05:12 PM
Mjet67's Avatar
Mjet67
They should work fine on your 85.
Old Jan 22, 2019 | 05:23 PM
BLUE1972's Avatar
BLUE1972
I had issues with the Champion , the Accel work well.
But my 85 's engine is worked.
I also use DEI Spark Plug Boots they help.
To Header spark plugs - Any recomendations?
