want to check compression. where do i
Old Oct 31, 2002 | 11:34 AM
quiksilver458's Avatar
quiksilver458
Default want to check compression. where do i
Where do i start guys? Speical tools needed, instructions ect.. would be greatly appreciated.. Seriously considering full rebuild again, and want to test how strong my bottom end is at 155+ thousand miles.. Car only burns less than half a quart after 3k miles.. Appears strong, pulls hard at all rpm's.. just wanna get an idea of what each cylinder is pulling.. thanx :)
Old Oct 31, 2002 | 11:49 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: want to check compression. where do i (quiksilver458)
Not that bad of a job. You'll need a compression gauge. It comes with sparkplug adapters in various sizes. Pick the one for your vette. remove one plug, screw in the adapter, attach the guage and bump the engine over a few times. Write down the cylinder # and the compression, reinstall the plug and move to the next cylinder. Don't forget to releive the presure in the guage before going on to the next.
vettmech's Avatar
vettmech
You need a compression guage and a plug socket and ratchet and whatever combination of adapters you use to change plugs. Dissable the ignition...... (pull the big wire out of the dist cap) You should also dissable the fuel pump (pull the fuse or unplug the relay). Screw the guage into the plug hole and crank the engine over 5 times. (the number of times is argued by some but most textbooks that I teach from say 5). you want the readings to be within 25% from the lowest to the highest. This is the worst case I would accept and for performance I would be a little more fussy. Look for any LOW or HIGH readings. A high reading could be carbon buildup and a low one is wear and tear. you can dertermine rings or valves by folloing with a wet test ( a teaspoon of ol in the cyl) if that brings it up it's rings .......if not it's valves.
To top it off if you have the equipment (air compressor) you can do a leakdown test. Many mechanics feel that this is better than a compression test because a compression test is also affected by cranking speed
Hope that helps :seeya
Old Oct 31, 2002 | 11:53 AM
quiksilver458
Default Re: want to check compression. where do i (vettmech)
what fast replies.. i can pickup one of this comp testers at like a parts store right? Im going to try and do this sometime this weekend.. thanks for the help, and i'll keep ya posted! :)
Old Oct 31, 2002 | 11:57 AM
vettmech's Avatar
vettmech
Yea it's available at all parts stores....... one other thing though ....... get the kind that SCREWS into the plug hole. There are some that one must HOLD into the hole and they SUCK!!!!!... you can get cheap ones and expensive ones.......... :seeya
Old Oct 31, 2002 | 12:00 PM
quiksilver458
good deal... thanx!! :cheers:
Old Oct 31, 2002 | 12:16 PM
Steel Blue 91
Get the kind that replaces the plug.
Old Oct 31, 2002 | 01:20 PM
SSLT1KID's Avatar
SSLT1KID
Default Re: want to check compression. where do i (Steel Blue 91)
make sure to take out all the spark pbefore you do this. if you hve a blown head gasket, the adjacent cylinder can help to hold the pressure and feed it own pressure if it has a spark plug in it.
Old Oct 31, 2002 | 02:26 PM
JonM's Avatar
JonM
AutoZone will loan you one.
Old Oct 31, 2002 | 09:38 PM
dlmeyers's Avatar
dlmeyers
Default Re: want to check compression. where do i (JonM)
Vettemech has a really good recommendations especially the last two sentences.
Sounds like you would really be interested in the results of a leakdown test. This test will help determine how much air (depending on the gauge set, may give a percentage, or green yellow red scale) is getting by the rings/cylinder wall.
Some good stores, (our local NAPA loans em out) may provide BOTH leak down and compression testers. Don't ya love those guys. Since the plug is out anyway, really good for making a sound decision.
90 Corvette zf6 3 speed shocks
Old Oct 31, 2002 | 10:23 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: want to check compression. where do i (dlmeyers)
They are 25 bux at pep boys.
Anyway take out all plugs when you do this, and crank engine until pressure in the gauge doesn't increase anymore.
Old Nov 1, 2002 | 09:16 AM
DaveD's Avatar
DaveD
Default Re: want to check compression. where do i (BAdAzZV8)
Block open the throttle body also so it can suck the air in without restriction.. And for sure remove all the plugs at the same time. That will also make it a lot easier on the starter and battery. If you have bad compression in a cylinder squirt a little oil in it and redo the test. If the compression comes back up its the rings. Real low pressure in two adjacent cylinders usually means bad head gasket between the two.
To want to check compression. where do i
