Power To Breaker
Old Jan 26, 2019 | 11:59 AM
CorvetteRules's Avatar
CorvetteRules
Default Power To Breaker
My power seats and door locks stopped working. All fuses showed ok, But the 30 amp accessory beaker shows bad. When I checked the breaker connection in panel it was showing over 12 volt, but that is with the key off. My question is if the key is off why would it show any current??
Old Jan 26, 2019 | 12:24 PM
CorvetteRules
Opppps, I think I answered my question. FSM shows the power accy hot at all times.
Old Jan 26, 2019 | 02:02 PM
CorvetteRules
I put a new breaker in, but it just constantly breaks and resets. So apparently it has a short somewhere along the line. Anyone that has gone through a similar issue have advise on where to start first?
Old Jan 27, 2019 | 05:03 PM
CorvetteRules
Electrical question is if the circuit is always hot does the breaker tripping mean that there is a hot wire directly going to ground. I've had to pull the breaker because it was getting hot to touch.
Old Jan 27, 2019 | 06:28 PM
gpierce's Avatar
gpierce
Either that, or something pulling too much current like a motor with a short. I'd start with unplugging the door lock and seat motors.
Old Jan 28, 2019 | 08:08 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
'87 was the first year that 6 way power seat was available on passenger side. Wire routing caused a chaffing on the power to the passenger seat, eventually causing short to seat rack and cycling breaker. The Action Center guys figured this out and sent out bulletins to the dealer network, but I can't remember at the moment if there was an actual TSB written for this. This only affected '87 models and was corrected for '88 on. If yours is an '87 might be worth a look.
To Power To Breaker
