Clutch Bleed Screw Broke?
I can't quite figure out what is going on with my clutch bleed screw on my 1990. Here's a photo I took with a mirror so I could see the top, where the bleed screw goes. Is the bleed screw sheared off or what? Thanks for the help.
Shouldn't there be a bleed screw here on my clutch cylinder?
[QUOTE=cache1;1598763467]I can't quite figure out what is going on with my clutch bleed screw on my 1990. Here's a photo I took with a mirror so I could see the top, where the bleed screw goes. Is the bleed screw sheared off or what? Thanks for the help.
Shouldn't there be a bleed screw here on my clutch cylinder?[/QUOTE
Like you suspect it appears the bleeder is broken / snapped off. You could try to use an easy out and try to remove and get a replacement bleeder or get a new Slave their not to expensive. Don't get me wrong with throwing new parts for minor problem but in the agrevation of getting the easy out cutting knuckles I would swap it unless it was changed not to long ago. Or not bother unless there is a problem that needs bleeding.
cache1 (01-28-2019)
Thanks for confirming my fear. The fluid in my clutch reservoir was nasty dark, so I sucked it out with a turkey baster and got clean fluid in there now, but I'm thinking the line is full of the nasty fluid still. That being said, the clutch feels fine under the foot. So maybe I will just leave it alone for now.
cache1 (01-28-2019)
I agree. I have put this clutch issue project on my perpetually revolving 'to do' list for the vet. There is always something I can be tinkering with on my car. But yeah, I didn't think about replacing the whole line in addition to the slave cylinder. Good suggestion.
