Mark VI Big Block Swap
Clearance at steering rack is tight. May need to cut and reweld steering rack mounts forward about an inch.
C3 BBC headers are a near fit with some mods needed.
Hood clearance is an obvious issue with the stock hood.
Gets tight at the HVAC box on the passenger side.
with that said, read this and make sure to follow all the embedded links, will provide lots of information:
http://garage.grumpysperformance.com...gine-swap.151/
Edit to add, The LS is probably a more efficient motor....
But the wow factor of a BBC is hard to top!!
its a 1986. I think I can get the bbc to run off of the stock tpi harness. I have been taking alot of videos, i am using this car and my monte carlo ss buildup to launch my youtube channel.
The premise behind the corvette build is this. The C8 corvette was finally greenlighted because Tadge produced a phenomenal best of the breed product in the C7, and then basically told GM that was the best he could do, and no matter what incremental improvements were made, that they had reached the practical limits of the architecture. This point was further illustrated by the 750hp zr1 not really being much faster around several major race tracks than the 640 horsepower z06.
but the c7 traces its architecture all the way back to the C5. C5 was grand daddy, but C4 was Genesis.
Clearly improvements were made, the most being from c4 to c5, but C4 had excellent geometry, aluminum suspension, abs, and a lower ride height and cog than its progeny.
all of that aside, I feel that a substantial portion of the handling improvement was made with tire technology. So what happens when we take a 2500 dollar car, spend 3500 on the drivetrain, and 4k in brakes and tires? How close can we get to a C7 Zr1 on a high school part time employees salary? Is it worth exploring? Will I have a huge amount of egg on my face? Can it be modified by someone with less than average mechanical ability? Without a fancy shop? I believe it can, and thats the point of the build.
An LT5 is one heavy chunk of metal I felt very little difference in fact only time it was apparent was really pushing it through tight twisties, didnt slow me down at all.
Id do it, that torque is flat out addicting and that thundering exhaust note....heck yeah! If you gotta hack up the hood go for it.
Theres enough stock ones out there.
