Slow pass on a slippery track...data inside.
How can I improve?
Picked up 30 mph between the 660 and 1320 including an up-shift during the interval. Some wheel slip present in 3rd and 4th gear. 160 ° t-stat and 2 1/4" exhaust must be holding me back...
Lots of time spent off throttle and significant time spent at low speed due to short-shifting certainly hurt et.
The 2k ppm distance counter actually does a pretty good job of tracking the distance and helping to determine where you are on the track at any given time. It resets every 0.128 miles...but has enough range to cover an 1/8 mile between cycles.
Shift speeds despite wheelspin should have been made around 6400-6500 rpm (partial gear chart corrected for my 3.73 gear, MH5 4+3 trans and 769 rev/mile tire):
6000: 44 66 94 126 202
6100: 44 67 96 128 206
6200: 45 68 98 130 209
6300: 46 69 99 132 213
6400: 46 70 101 134 216
6500: 47 71 102 136 219
Gear chart is always fun to play with:
http://www.pszweb.com/car/gears.htm
https://datazap.me/u/tequilaboy/strip-120?log=0&data=60-107-116-120&solo=116-120&zoom=409-644&mark=468-535-569-482
This correlates pretty well with what I know from the timeslip ~90 mph at the 1/8th with 120 mph trap. Its not perfect, but gives a pretty good idea of distance/track position. With wheelspin, the distance counter will accumulate distance a bit faster than the car itself, so some error is expected due to slip.
I know launch rpm was a bit too high...My A/C based launch rpm control function wasn't working due to an open low pressure switch. Took me awhile to figure out what was wrong and jumper the switch...might have a test log showing this in action somewhere...gotta do some more digging.
Note: I've got a pair of 88 16" wheels that are intended to be mated to bias-ply Hoosiers (likely the Quick Time Pro) which would solve most of my issues, but still interesting to talk about getting down the track under traction-limited conditions and the data can be interesting to look at. Datazap makes it easy to share log data since it is platform independent, but doesn't seem to be catching on with this crowd.
https://datazap.me/u/tequilaboy/ac-launch-rpm-control-test?log=0&data=57-60-66-72-93-116&solo=72-93&zoom=563-951
Press button...wait...launch from idle @ 1800 rpm...pedal it from there...
This works by exploiting the A/C on Idle Speed Adder along with appropriate adjustment of throttle stop screw and tps. IAC can add about 1,000 rpm to the base idle if properly adjusted.
I forgot to mention unplugging the A/C compressor also helps. Nobody wants A/C compressor drag while drag racing.
Sometimes the links don't show the expected content...You may have to play around a bit to turn signals on/off or zoom etc. something going on with the parsing of the links.
https://datazap.me/u/tequilaboy/launch-test?log=0&data=11-57-60-72-93-116&solo=72-93&mark=20-40
Original log file also includes 2 launches and full passes, but I need to trim it down for datazap first. File is too big to upload.
Launch rpm control in action again...in 2nd gear this time ha-ha:
https://datazap.me/u/tequilaboy/laun...0&zoom=330-629
Thanks for the feedback.
Thank you. I posted about this years ago. Nobody seemed to understand. My tires did not squeal when spinning and it took a while to determine the cause of the knock counts. If the car hooked, no counts at all. A bit of sand on the blacktop and the knocks counted up.
https://datazap.me/u/tequilaboy/1st-gear-launch?log=0&data=4-15-18-24-30-58-62-67-71&solo=30-67-71&zoom=6530-6931
Hit the rev-limiter in 2nd gear spinning around 70 mph, then recovered after fuel cut...almost looks like a traction control event.
