Your help with modification ideas please.
The car pulls very hard in the first four gears. To the best of my knowledge it is mainly stock.
I have change the timing + 4 deg, air foil, duel air filters, Now cold air inducted. K&N filters, 8.8 plug wires, free flow exhaust with flow masters.
I am thinking that I would like to go with 1.6 rockers, Port/polish the heads and intake. 2.0 Intake and 1.56 Exhaust valves. Comp cam has one that shows 208-214 dur and 452-468 lift. with the 1.6 I would be in around 490-500 range. This would keep me in the high-low end torque and fast revving plan. With just maybe the 5-600 more rpms than I have now. I am considering short headers since my car is lowered and I already can't go over a peanut. I would then need to focus on the distributer to bring that up to the new requirements.
Anyone been this route any ideas. thanks
:cheers:
25-30 cam (like ZZ-9 or Super L98)
25hp ported & worked #113 heads
Instead of shorty headers, do a hi-flow front Y and port your stock headers, along with a hi-flow cat. It might be worth 15hp or so.
Either go with the BM intake base and LT runners (15hp) or try the siamese base with stock runners (20hp at 5,400rpm). A 52mm TB and ported plenum would also be a good idea. You will definitely need some kind of intake mod to supply enough air for the heads and cam.
A HyperTech coil/cap/rotor and cut-back AC Delco plugs gapped to .045" will assure good top end firing and bring another 10hp.
Though an AFPR may be enough for tuning you may also need a custom chip with the cam, depending on how your vacuum holds.
I think your stock injectors may just keep up with those needs (350-370hp at the crank).
When you do the heads & cam chose springs to match the cam with 1.6 RRs, toss the oil sheders and go up to Ti retainers with 10deg locks. A set of 7/16" studs wouldn't be a bad idea either.
That combo should push your shift points over 6k RPM and provide a nice boost in HP and torque.
I'm sending you some data on results of similar mods.
I agree the heads and intake need to flow more. Does the factory intake have enough removable material to make this happen. I have debated on siemesing the stock runners like I have seen here on c/f. Does this take away from the low end more than I would like. Giving that I will not be going up in Cubic Inches. :confused:
