Could this equal a high 12?
Old Oct 31, 2002 | 06:21 PM
daddydahlin's Avatar
daddydahlin
Default Could this equal a high 12?
With the mods I have in my sig. I ran a best of 13.98@96.81mph. My goal is too with a stock motor run a 12.9. My plans are Hooker super comp. headers, AFPR, a transgo shift kit, and a 2300-2500 torque conventor from Pro-Street Intruder. Can a 12.9 be accomplished with these mods or is it going to take alot more? Thanks
Old Oct 31, 2002 | 06:33 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: Could this equal a high 12? (daddydahlin)
that stuff will certainly help. However, a 12.9 is pretty fast...
FoolCrzy's Avatar
FoolCrzy
Default Re: Could this equal a high 12? (FoolCrzy)
get some drag radials too...
Old Oct 31, 2002 | 06:39 PM
daddydahlin
I was looking at drag radials too, but I was hoping to do this on street tires , right now I can pull low 1.9 60'. But I have also heard of people dropping .3-.4 with DR.
Old Oct 31, 2002 | 06:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The headers over a stock front Y might give .2sec, you might see another .3 from the TC and shift kit and the AFPR will give a little as you no doubt need a little more fuel by then.
If you can get one of those cold Feb days at Brandenton along with a high baro you may get to low 13s but I don't thing that will be enough for 12s.
Anyway allow yourself some time to learn to launch with that TC; try launching a few hunderd below stall for best results and stage as shallow as possible.
Old Nov 2, 2002 | 03:43 PM
daddydahlin
Default Re: Could this equal a high 12? (65Z01)
I was told that a higher torque convertor was good for .5 alone
Old Nov 2, 2002 | 03:46 PM
J Z06's Avatar
J Z06
Default The 12's
Vic'89 and 65Z01 have similar combos. Vic has clicked a 12 second pass a time or two, 65z01 is on the verge. If I had to do it over again, and could limit it to a bolt on 12 sec car...I'd be duplicating their package. Believe me, I see these cars approx once a month, they're durable and their times are consistent. :cheers:
Old Nov 2, 2002 | 03:49 PM
vader86's Avatar
vader86
Nope, youll need more than that.
BBA's Avatar
BBA
That all depends on the vehicle specifics. You have a low RPM torque motor, stalling at a higher RPM will only help but so much, but it will help. I just can't see .5 seconds worth unless you did smoe mods to make high rpm power...like porting the intake/siamese the intake base runners, change cam ( roller preferred ), change valve springs and do a custom ECM chip. Do all of that...12's would be easy.
SSLT1KID's Avatar
SSLT1KID
Default Re: The 12's (JD 90 383)
i think wats really ging o oldyu back is those gears. with all those mods and gears, that could put you into the 12s.
Old Nov 2, 2002 | 04:42 PM
daddydahlin
Default Re: The 12's (SSLT1KID)
I don't want to change the gears until I have done some mods to gain some higher rpm power, so I'm going to sick with the 2.59's for now
Old Nov 2, 2002 | 06:01 PM
VetteNoob's Avatar
VetteNoob
Default Re: The 12's (daddydahlin)
With those gears, I dont think the mods you are planning will get you into the 12s. If you do the gears and everything else you said, you have a shot at 12s. IHO
Old Nov 2, 2002 | 06:12 PM
daddydahlin
Default Re: The 12's (VetteNoob)
I thought that lower gears would hurt performance due to the fact that the L98 doesn't make much high rpm power and thats why they came with the 2.59 or 3.07 gear
Old Nov 2, 2002 | 06:18 PM
VetteNoob's Avatar
VetteNoob
I agree that if you went went too high with the gearing, you'll be spent too soon, but I just think with a TC and some 3.45s, if you can make it stick, you could get close to 12s with the mods you have planned. Even 3.07s would help. Maybe do a little home porting work on the TPI to get a few more rpms. I could be completely wrong, but I just dont think the 2.59s will get you there fast enough. You're looking to shave off a whole second and every little bit will help.
Old Nov 2, 2002 | 06:23 PM
daddydahlin
Looks like I've just have to save a little more $ for some gears now, I'mm just trying to plan every thing out before I do anything. I want to make a very compatible set up, yet still leave a little room for improvements
Old Nov 2, 2002 | 06:48 PM
VetteNoob's Avatar
VetteNoob
Ill be doing much of the same as you are with the 86 while I build up another motor. We have similar cars, except I have 3.07 gears in mine. Ill be installing TPIS headers and ported/semi-polished plenum and runners in the next few months and then it's off to the tracks (if it aint closed by then). Ill keep you posted to the times I run. Only thing that I may not be able to do is a TC (money) :( Good luck and hope you see some 12s.
Old Nov 2, 2002 | 06:54 PM
daddydahlin
Go to KDSperformance.com there TC are priced pretty good they say they fit the 700r4 so they sould fit. The one I'm looking at is a 2300-2500rpm for $179. I think I will wait on the gears and finish the other mods first then get a dyno run to help me decide what gear ratio to go.
To Could this equal a high 12?
Old Nov 2, 2002 | 07:29 PM
quiksilver458's Avatar
quiksilver458
definitely need those gears.. 2.59's will give you low rpm's and better gas mileage, but does not help you get out of the hole and run a fast 1/4 mile without serious mods.. :)
Old Nov 2, 2002 | 08:13 PM
dgoodhue's Avatar
dgoodhue
Your not going to be able to do it on street tires and it is going to be tough with the iron heads + pre roller block.
I also would swap in a set of 3.07, you have too many factors already against you and 2.59 are just going to make it that much harder.
If you going to buy and install a TC, get a real TC like the Vigilante. If you have the original stock TC, it should stall to 2200-2400 already.
Old Nov 2, 2002 | 09:43 PM
Goody's Avatar
Goody
Default Re: The 12's (dgoodhue)
I agree here. You get what you pay for. Buy a quality product the first time. It'll save that tranny from frying and you won't be replacing the same part twice.
