J55 brake rotors
Old Feb 12, 2019 | 06:38 PM
jv_72_jv's Avatar
jv_72_jv
Default J55 brake rotors
Anyone know what the difference is between the left and right front 13” rotors ? Parts places list two different part numbers for left and right. I don’t see the difference. I want to use NOS rotors and can’t find both left and right, just right. One guy has three 10257632 RH rotors available and says they fit left and right sides.
John
Old Feb 12, 2019 | 08:59 PM
ChumpVette's Avatar
ChumpVette
Originally, the rotors were cast with directional vanes. Now everybody is cheap and just does one rotor to be used right or left.
Old Feb 12, 2019 | 09:10 PM
jv_72_jv's Avatar
jv_72_jv
Thanks for the reply! I figured that was the case even though the aftermarket parts catalogs list left and right separately. I wouldn’t over think it and just buy some ACDelcos (probably China).
Thanks,
John
Old Feb 12, 2019 | 10:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If drilled/slotted orientation might make a difference.
Old Feb 12, 2019 | 10:41 PM
WVZR-1's Avatar
WVZR-1
10257632 is a RH J55 only. Yes it could be used on either side but if it's actually that # it's RH 'orientation'. If it were an actual GM 10257632 it would/should also have 'black' hats and meant for GS etc.
J55 correct 'orientation' should be an easy find!!! Very easy!!
Old Feb 13, 2019 | 09:56 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
I just went through this. Check out the diagram on post #7.
https://www.corvetteforum.com/forums...nt-rotors.html
To J55 brake rotors
