Fuel pressure pump Inline add on?
Old Feb 14, 2019 | 01:34 PM
Street89vette's Avatar
Street89vette
Default Fuel pressure pump Inline add on?
Fuel pressure from stock 89 looks like 20-30lbs. Is this normal and can I add a inline high performance pump without flagging the ECM?
Old Feb 14, 2019 | 02:21 PM
3D-Aircrew's Avatar
3D-Aircrew
That's too low should be 40-45psi. You need to diagnose what's wrong with your fuel system. Maybe a clogged fuel filter, sock or a bad pump or Fuel pressure regulator.
Old Feb 14, 2019 | 04:32 PM
vader86's Avatar
vader86
Too low, should be about 42-45ish.
Change the fuel filter if it has never been, or not recently changed, but I suspect your pump is dying. The FPR can go out as well.
You can replace the pump with a Walbro or other Racetronix unit, and if you do that, you need to do their in-tank wiring upgrade as well as their piggyback harness if youre adding any real pumping power over stock.
The ECM does not care, its designed assuming a pressure value, and uses a pulse width and an injector size in its calculations.
Old Feb 14, 2019 | 06:33 PM
JackDidley's Avatar
JackDidley
Vader has it right. Easier to replace the stock pump than to add a pump in line anyway.
To Fuel pressure pump Inline add on?
