'96 AIR injection delete?
Old Feb 16, 2019 | 09:55 AM
C4Newb's Avatar
C4Newb
Default '96 AIR injection delete?
Hi all, I've searched and found info on the older models but nothing for '96 OBD 2ish. Was wondering if removing the AIR injection on a '96 LT4 will throw a CEL/code? Guessing yes but maybe someone knows for sure.....
Thanks!
Phil
Old Feb 16, 2019 | 04:28 PM
PatternDayTrader's Avatar
PatternDayTrader
Yeah PO410 I think.
Old Feb 19, 2019 | 08:48 AM
MatthewMiller's Avatar
MatthewMiller
It will, but you can turn that diagnostic test off in the PCM if you use Jet DST to tune it. Just curious why you want to delete the air injection?
Old Feb 19, 2019 | 09:05 AM
KyleF's Avatar
KyleF
It has been proven there is no real benefit power wise to remove the AIR injection. It doesn't weigh a lot.
If you are keeping this as a street car, just keep the system.
Old Feb 19, 2019 | 12:02 PM
mixalive's Avatar
mixalive
Yes it will throw a code. But, if you leave the relay connected to the wiring harness, you can remove the air pump and all the piping and no code will be thrown. The computer senses the air pump from the relay, not the air pump. This worked for my 92.
Old Feb 19, 2019 | 12:57 PM
belairbrian's Avatar
belairbrian
While I agree that works on an OBD I car, the OP has OBD II and I believe downstream O2 sensors. With Downstream sensors the diagnostics can monitor changes post catalyst to see if the air injection is working properly.
Old Feb 19, 2019 | 01:15 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
last summer while having my 1996 lt4 tuned, i had the air system tuned out as i had removed all the hoses and pump. so far, no codes.
Old Feb 19, 2019 | 04:04 PM
MatthewMiller
Yep, that's exactly what I was getting at. And with the LT1/4 cars, there's really no power benefit since the pump is electric.
Yes, the 96 is the one year of C4 where this is true. And these days, Jet DST is the only software available that can be used to tune a 96.
Old Feb 19, 2019 | 07:54 PM
C4Newb's Avatar
C4Newb
Agree on all counts, I don't necessarily want to remove it as it is a zero sum game performance wise, I just came into possession of a set of headers that don't have the correct bungs for the AIR tubes. Based on the responses to this post and other research I will simply machine and weld on the correct bungs for the AIR injection tubes and leave it as factory.....
Thanks for the responses!
Old Feb 19, 2019 | 08:01 PM
KyleF's Avatar
KyleF
I didn't see where you mentioned your location. I am assuming since you are asking this question you are in an area that doesn't do a visual or tailpipe inspection. Another vote to keeping the system is if you ever think you may relocate to an area that does or if the laws in your area may change.
To '96 AIR injection delete?
