MT2500 Questions
Old Feb 21, 2019 | 08:01 PM
Ryanflathead45's Avatar
Ryanflathead45
Default MT2500 Questions
I friend of mine offered to give me a MT2500 that he got on trade a long time ago.
He said it doesn't have any cartages or keys. And he can't remember what cords he has.
So I guess long story short I've been trying to learn about them. Seems like there are tons of different cords, cartages, keys etc. I'm totally confused what basis items I would need to make it work on my 1986 corvette.
Or if it is even worth messing with if I have to buy all the small pieces.
Any advice would be great
Thanks in advance,
Ryan
Old Feb 21, 2019 | 08:25 PM
Kevova's Avatar
Kevova
Just the "brick" is very good. You will need cartridges and power and gm aldl cords just to find out if it works. If you had a MT2500 a spare unit would be good.
Old Feb 21, 2019 | 09:46 PM
aklim's Avatar
aklim
Thanks in advance,
Ryan
Go to a GM dealership armed with your scanner with a fresh battery and a box of donuts. See if one of the techs can lend you a cable they have and a cartridge so you can verify that it works. I'd verify it BEFORE buying any cables or modules. Or find the Snap On guy. He might be able to help.
Old Feb 22, 2019 | 09:50 AM
mlm0's Avatar
mlm0
I have one for my 89 and love it. If would like pm me and I will send you pictures of the only two things you need to make it work so you can buy them, maybe off eBay
Old Feb 22, 2019 | 11:43 AM
s carter's Avatar
s carter
I am not discuriging or discounting what others have said. If you can prove it works and get needed keys and cables for a fair price great. But I was able to get one on let go for $125. About a year ago. Just ran it offer up low end $100. Top end$450.+-
Old Feb 22, 2019 | 04:05 PM
mlm0's Avatar
mlm0
Here is what I needed for 89
first picture is adapter that you should have gotten with mt2500. It is cord that plugs into machine
2nd picture is same plug. This is the end that will plug into all other adapters. The other end plugs into machine
3, 4 and 5 are pictures of adapter that you need to plug into your car under dash on one end and the other end connects to machine. Number 5 shows where the power cord plugs into the adapter to provide 12 volt power. I found a number of the 12 volt adapters listed on amazon for about 20.00
6 and 7 show 12 volt power adapter needed 7 shows it plugged into adapter
8 shows the only cartridge you need
hope this helps
Mike
Old Feb 22, 2019 | 05:19 PM
aklim's Avatar
aklim
[QUOTE=s carter;1598927466]If you can prove it works and get needed keys and cables /QUOTE]
"IF" being the operative word.
Old Feb 23, 2019 | 10:16 AM
Ryanflathead45
Thanks for the pictures. They are very helpful.
What does the AC power cord on the side of the GM adapter do?
Old Feb 23, 2019 | 10:26 AM
mlm0's Avatar
mlm0
It’s not AC, it’s 12 volts and plugs into cigarette lighter slot to provide power for under dash adapter to work. You have to have it
Old Feb 23, 2019 | 03:59 PM
Ryanflathead45
I'm not sure why I said AC duh. But I got ya. I did not realize the adapter needed 12 volts.
Old Feb 23, 2019 | 04:31 PM
mlm0's Avatar
mlm0
If you get it working, you will love it. It helps you set min idle specs, and can provide you with real time specs while running
Old Feb 24, 2019 | 10:16 AM
Steve59's Avatar
Steve59
Check out Ebay for the connectors, cartridges, etc. I bought the whole set up, MT-2500 and assorted goodies AND manuals for $150 about 4 years ago.
Old Feb 27, 2019 | 12:29 PM
Ryanflathead45
Well I have an update. My buddy brought the scanner to work yesterday and gave it to me for free. But its a snap on Solus, not a MT2500.
For a quick search it seems this is the replacement for the MT2500. But the cables are the same...I think.
To MT2500 Questions
