‘93 Throttle not closing
Old Feb 21, 2019 | 09:16 PM
Galaxie500XL's Avatar
Galaxie500XL
Default ‘93 Throttle not closing
Driving earlier, my ‘93 LT1 decided to begin idling at 2500 RPM. Shut it down, an saw the throttle was staying a good distance away from the throttle stop screw. I was able to close the throttle by hand, restarted, and the idle was normal...UNTIL I pressed the accelerator, at which point the throttle again stuck away from the throttle stop.
Shut out the car back down, was able to note tension on the throttle cable. Moved the throttle closed by hand, and checked the throttle for free movement. All seemed normal moving the throttle by hand. While still shut down, pressed the accelerator, and once more, the throttle would not return to closed.
Bad accellerator cable, or is the ASC module/ASC cable involved in what I’m seeing?
Old Feb 21, 2019 | 09:34 PM
Kevova's Avatar
Kevova
Codes ? debris in throttle body? FSM ? ASR actuator adjustment?
Old Feb 21, 2019 | 09:44 PM
Galaxie500XL
No codes...throttle body moves freely, and the ASR actuator hasn’t been adjusted in the year I’ve owned the car.
It appears the accelerator cable isn’t retracting all the way to allow the throttle to close completely, even with the engine shut off.
Old Feb 21, 2019 | 09:56 PM
Kevova's Avatar
Kevova
Floor mats or hush panel. Make sure pedal itself is free. There isn't a simple way to bypass actuator. If the cables are not binding i would be looking at actuator. If you turn off ASR does it change anything?
Old Feb 21, 2019 | 11:38 PM
Galaxie500XL
Nothing seems to be in the way..turning ASR off doesn’t seem to affect anything...in fact, I can create the problem with the car completely shut down by pressing the gas pedal.
Old Feb 22, 2019 | 08:42 AM
C409's Avatar
C409
….. Spray lube it … I use silicone based spray lube … With the snorkel off , engine off , spray liberally at all points where the throttle shaft passes through the throttle body while working the throttle by hand … this should be on your once a year maintenance list like maybe on the day you remove the trash thats between the radiator and A/C condenser …..
Old Feb 22, 2019 | 09:37 AM
jmgtp's Avatar
jmgtp
I’d stay away from silicone spray, it will degrade oxygen sensors, spraying in or around the TB may find it’s way in. The bushings in the throttle body may be worn in which case it would need a rebuild or replacement.
ASR cable has an adjustment detailed in the FSM. Worth a check.
Old Feb 22, 2019 | 09:57 AM
jmgtp's Avatar
jmgtp
Hopefully this link works, from the Society of Automotive Engineers...
https://www.sae.org/publications/tec...ontent/860478/
Old Feb 22, 2019 | 10:57 AM
Galaxie500XL
We’re having a bit of a monsoon here, but went outside for a bit, pressed the accelerator, which popped the throttle partially open again. Found an adjustment button on the cable going to the throttle, pushed the button, and the throttle closed with a satisfying click. Drove around the neighborhood a bit, and the throttle appears to be operating properly.
I’ll get my FSM out, and read the proper method for adjustments, but at least for now, the car isn’t trying to do 30 in my driveway.
Old Feb 22, 2019 | 04:19 PM
DGXR's Avatar
DGXR
The bushings on the throttle plate/throttle body mount are known to wear out, so check those. If they are not good, the throttle plate won't align correctly with the body and will hang up as you are describing.
Old Feb 22, 2019 | 04:22 PM
Galaxie500XL
That’s very true. I have an ‘88 L98 IROC, and encountered that problem. The LT1 throttle body looks more or less identical.
To ‘93 Throttle not closing
