Dumb LT4 Hot Cam Question
Old Nov 1, 2002 | 09:00 PM
tomservo's Avatar
tomservo
Default Dumb LT4 Hot Cam Question
Or just a cam replacement question in general...
When doing a cam replacement, given that the LT4 Hotcam Kit comes with new rockers, should I replace the lifters too? Or is that really necessary? If it is recommended, any thoughts on whose?
Old Nov 1, 2002 | 09:06 PM
95AquaC4's Avatar
95AquaC4
Default Re: Dumb LT4 Hot Cam Question (tomservo)
I wouldn't think so. However, it is recommended to replace the springs with the LT4 springs.
Old Nov 1, 2002 | 09:09 PM
Goody's Avatar
Goody
Use the same old roller lifters, but you must change the springs.
Old Nov 1, 2002 | 09:15 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Dumb LT4 Hot Cam Question (Goody)
Check the lifters carefully... my car is in the shop as week speak for a Hot cam and two of the lifters were bad, they were starting to wear the cam lobes they road on. Not bad.. but bad enough that is was quite visable.
Old Nov 1, 2002 | 09:19 PM
tomservo's Avatar
tomservo
Oh definitely. They are part of the kit actually.
Thanks for the info!
Old Nov 1, 2002 | 09:53 PM
superlund's Avatar
superlund
As much work as it is to install the Hot Cam kit why not just put in a new set of lifters? I know you can get away with reusing the previous roller lifters but the peace of mind you get with new lifters is worth the extra cost involved. The problem is lifters have moving pieces inside & you can't see the wear. I bought a brand new set in GM packages on Ebay for under $150 just my two cents. :)
Old Nov 2, 2002 | 08:13 AM
tomservo's Avatar
tomservo
Default Re: Dumb LT4 Hot Cam Question (superlund)
Really no reason I couldn't. Fact is the motor is out of the car so access is no problem! :) I was just wondering if I needed to or not, the lifters are fairly new, but it might not hurt to replace them. I just wasn't sure if it was a necessity to do so or not....
Old Nov 2, 2002 | 08:45 AM
superlund's Avatar
superlund
Try here; http://cgi.ebay.com/ws/eBayISAPI.dll...tem=728923846;
To Dumb LT4 Hot Cam Question
