Opinions on Best Shocks & Struts
Hi All,
I know this has been covered in the past, but I thought perhaps a more recent update to this subject is in order with newer/fresher opinions.
My 1988 came with the Z52 package and Bilstein shocks. At some unknown point in the past, the previous owner installed KYB Gas-A-Just front and rear.
At this point the KYBs look kinda tired. On one hand I'd like to go back to the Bilstein as that's what the car originally came with. I like the look/have heard good things about the QA1's (not looking at the adjustable ones, though).
Can anyone with actual experience chime in on what they prefer between these three types of shocks & struts? Just curious to get some feedback on what people liked best.
Hi All,
The new Bilsteins made absolutely no difference in correcting my problem.
I then purchased 4 QA1 double adjustable shocks from Summit Racing. First I had a mounting issue on the rear shock eyelet. I called QA1 (terrible customer service at least for me) they said they knew nothing about this and suggested I add some spacers!
I machined two spacers to fit the mounts perfectly. Went for a ride and the car was bouncing and oscillating like I had a horse and carriage for a vehicle. I tried adjusting per instructions, then I called customer service at QA1 yet again and got no where.
Called Summit Racing and told them the situation and they said they would give me full credit towards a new set of shocks. I asked them what they recommended for my 96 Z51 Vette. They told me that the Ridetech shocks are excellent, they are only a single adjustable (rebound) but should work really well.
So I swapped them out. Now to be fair the QA1 shocks after removal were leaking at the piston on two of the four shocks (mind you I never put 4 miles on the shocks) maybe they were defective? Don't know!
But the Ridetechs are really well made (made in collaboration with FOX), the minute I put them on what a difference in handling. I settled on a firm setting but you can make them smoother then the Bilsteins if that is what you prefer. It is all just a **** click away. And the ***** are easy to access and the fitment was dead on (order the Corvette Set of four so they send you the correct application because you can order them front or rear only but those are universal and may have the wrong mounting hardware).
In my opinion Ridetechs are fantastic shocks and they warranty them for a million and one miles.
Goodluck with your choice!
carsofchaos (03-08-2019)
I agree with grandspt about the Ridetechs.
Great info on the Ridetechs I had not considered them before. Sounds like a miserable experience with the Q1's...perhaps yours were defective but sounds like the customer service experience alone is bad enough to make me shy away from them.
My ride is pretty much stock as I have not done any crazy mods to it other than Borla exhaust. In the past (and on a couple different cars) I've had mixed feelings about the KYBs which is why I am looking to possibly ditch the current KYBs in my Vette. While I can handle a stiff ride fairly well the condition of New Jersey roads are not kind to a car with extremely stiff suspension. So I am looking for a happy medium.
I have had a couple people tell me they noticed no difference between the performance of the Bilsteins and the KYBs, so I'm a bit clueless as to why people would pay 2x as much for the Bilstein setup as the KYBs if there is little to no difference in ride. Maybe people like the yellow color?
I currently have Z51 Bilsteins (B8) on one car and KYB's on another car. I have also had the base Bilsteins (B6) on a couple. The Bilsteins are better shocks.
The KYB is the softest street ride of the three.
My preference is the Z51 (B8) shock (even on a base suspension car). They are firmer, but still not harsh. My experience with the Bilstein shocks on a bunch of cars is that they last very well. Basically they may be the last shock you need to buy for your car.
I have heard a lot of reports where the KYB do not last very well. So far mine are fine, but I bought the car with them on it and don't have many miles on it yet.
About 25 or 30 years ago, KYB was the oem supplier to the car manufacturer I was an engineer for. They had problems. I worked at their plant quite a few times over several months trying to make improvements. At that time even when improvements were made, their management had problems that they could not control their processes. I repeatedly found problems at their plant and many times it was the same problem that they had before. They were a very poor manufacturer. I hope they have improved since then, but I will never buy their shocks because of the experience that I had with them.
Good luck.
Good luck.
Received 1,401 Likes
KYB is a shock for someone who just cruises. I definitely recommend Bilstein.
Thanks guys all this info is very helpful and what I was looking for: reports from people who've had experience. I am definitely ready to ditch the KYB setup.
For about 3 seconds I was happy to find a full set of Ridetech's on Ebay for $490 that were almost new (mounted one time according to the seller) but sadly these are for 89 and up Vettes but thought I'd mention it in case someone is interested. Here's the link for those: https://www.ebay.com/itm/Ridetech-HQ...e3a0%7Ciid%3A1
Really wish I could use them on my 1988!!!
