35* outside, time to go pull the superram.
Old Nov 2, 2002 | 12:07 PM
scorp508's Avatar
scorp508
Default 35* outside, time to go pull the superram.
Lets see how many bolts I get off before I say F' this and go inside for heat. :lol:
Old Nov 2, 2002 | 12:09 PM
J Z06's Avatar
J Z06
Default SR
:lol:
mine just went back up, yours is coming off. mine is coming off again soon though.
might be a little off topic...i had my injectors cleaned and flowed(a few filter caps we're replaced) it starts MUCH easier since I did this.
good luck today, and let us know how you make out. oh, you're going to love that holley regulator. :yesnod:
Old Nov 2, 2002 | 01:28 PM
scorp508's Avatar
scorp508
i can't feel my fingers so excuse my typing
just pulled the plenum off. I pulled the connectors to all of the injectors and it still leaks down. that rules out the wiring. they're coming out!
Old Nov 2, 2002 | 01:41 PM
J Z06's Avatar
J Z06
Yes it's a bit chilly! I was thinking on cleaning the car...Umm, I thought again :D. Leaky injectors eh? Sucks! but at least you know. You we're right, that sr disassembly didn't take you long. :cheers:
Old Nov 2, 2002 | 02:03 PM
8388's Avatar
8388
St. Jude Donor '14
Default Re: 35* outside, time to go pull the superram. (scorp508)
Been there done that. I think it's a disease, or a malfunctioning gene. Done it even when it's in the 20's. We're just die hard hot rodders. :cheers:
Old Nov 2, 2002 | 02:20 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Yup... winter is finally coming, 76 out, windows are all closed up and the heat is cranking :jester
Old Nov 2, 2002 | 02:28 PM
scorp508's Avatar
scorp508
Update :cuss
Old Nov 2, 2002 | 08:32 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: 35* outside, time to go pull the superram. (Springer's LT4)
76 outside :rolleyes: Try snowing like a motha for the past week and 4 inches of snow just last night! And oh yeah the windows are all sealed up.
Its gotta be cold working on that SR in the cold. Putting it back together is gonna be tough with numb fingers! Good luck. Glad you found the problem :cheers:
Old Nov 2, 2002 | 08:44 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: 35* outside, time to go pull the superram. (ski_dwn_it)
SpringersLT4,...76 degrees in Florida...how would it be!!!
To 35* outside, time to go pull the superram.
