FX-3 trouble code 13 ?
Old Nov 2, 2002 | 12:30 PM
Kehrer923's Avatar
Kehrer923
Default FX-3 trouble code 13 ?
I have a trouble code 13 left rear timed out?
Anyone have more info on this
Old Nov 2, 2002 | 01:17 PM
c4cruiser's Avatar
c4cruiser
Default Re: FX-3 trouble code 13 ? (Kehrer923)
This code is set if the actuator is moving too slow or not receiving the the feedback signal.
Remove the actuator and turn the ignition to "ON". Does the gear turn?? If it doesn't, it's probably bad.
Try to turn the shaft at the top of the shock. It should turn easily. If it doesn't, the shock is probably bad. Bilstien can rebuild shocks for a very decent price.
There are some electrical checks that can be made at the wiring connector, but the most common problems are a bad actuator or the shock.
Old Nov 2, 2002 | 04:40 PM
dlmeyers's Avatar
dlmeyers
Default Re: FX-3 trouble code 13 ? (c4cruiser)
If you run out of trouble shooting ideas, (I finally did, after following the manual too), just move the left actuator over to the right side. And the right side over to the left. Just make damn sure the shock valve is not stuck.
I finally had to do this for my 90's front actuator, everything checked out except it didn't work. Finally swapped actuators, problem moved from RF shock to LF shock and new actuator fixed it.
Would recommend following the trouble shooting procedure listed in the manual.
dlmeyers 90 coupe zf6 3 speed shocks
To FX-3 trouble code 13 ?
