Brake problems
Old Mar 17, 2019 | 01:26 PM
PatzwaldB's Avatar
PatzwaldB
Default Brake problems
HI folks, I purchased my 1985 C4 last fall. I have had my share of problems but the big one is brakes locking. I have replaced both front brake lines and the drivers front caliper and hub bearing as it was locking up. The right side was warm but not as bad. I drove the car a month or so and got a brake light. Drove again yesterday and after about 3 miles got a brake light and upon returning to the garage both front wheels were very hot. I am not sure where to turn next. Usually brake locking issues are calipers and hose problems but I am thinking master cylinder. I don't think the '85 had abs. I have never ran into a master cylinder causing brake locking problems but always a first for me. Any suggestions.
A bit of history.. The car has 110000 on it but hadn't been used much recently. There had a been a lot of maintenance done on the car but I am suspicious concerning the quality. It had recently had a brake job as pads look brand new.
Thanks for the help. Bob
Old Mar 17, 2019 | 02:08 PM
Kevova's Avatar
Kevova
Check brake pedal be sure it fully releasing. Hush panel, brake switch misadjusted, booster leaking vacuum hissing noise from dash, master cylinder not fully returning. When front brakes a dragging if you open bleeder does fluid squirt out with brake pedal released. Since brakes are getting hot enough to turn warning light on; I would flush brake fluid DOT3 or 4 DO NOT USE DOT5.
