Tranny Issues Update Still Stumped
Old Mar 17, 2019 | 10:21 PM
Skylerjm1209's Avatar
Skylerjm1209
Cruising
Default Tranny Issues Update Still Stumped
Alright so a while ago i wrote up a post about an issue im having with my 700r4 in my 85 vette. The car trys to lurch forward in park and reverse and drives in neutral. Drive is fine I can drive the car normally in drive and it shifts from 1st to 2nd to 3rd to 4th just fine. I heard there was a retaining clip inside the pan on the top of the shift lever that controls reverse and neutral and is commonly the cause in some 700r4. My car has a different rod with just a bend in it with no clip anyone have any ideas?
Old Mar 17, 2019 | 10:28 PM
PatternDayTrader's Avatar
PatternDayTrader
Sounds like your shifter is not adjusted properly.
Old Mar 17, 2019 | 10:42 PM
Skylerjm1209
Cruising
Should have added that part i cam disconnect the linkage and shift the tranny by hand with the car on jack stands and it behaves the same way.
Old Mar 19, 2019 | 11:02 AM
confab's Avatar
confab
I've seen welded forward clutches do this.. The fluid condition will be poor and there will be friction material in the pan.
To Tranny Issues Update Still Stumped
