85 oweners help with vacuum routes
If you can take the pic further away we can blow it up still, anyway that is incorrect. That vacume should have a small
check valve connected, then the heater controls which come out from behind the dizzy and a seperate line should go over to a tee for cruise and the ball. As in the pic I posted earlier. I dont think a hard line went to the cruise side, only the heater controls came from the abiss.
Right now you will be stuck on defrost I believe. You will need the 5 dollar check valve to split the heater and cruise lines.
when i get home im gonna play around, found the 2 vacum lines coming from the cruise one to a T which is up and goes to the canister, the other ducks under the master cylnder and then i lost track of it, gonna dedicate some time and more lighting, lol, id like to slap the designer who used plastic...lmao, nut i do appreciate all the input
If everything's back started it up the fan was on when I started it and it had a little bit of roughness but smooths out Nash and it eventually shut off and kicked on when needed idles a little high but I think the TPS got knocked around when I move the plenum while it was off one thing I'm concerned about it's the front of the throttle body the bottom driver side there's a tube metal nipple she gets seal does not get sealed I've seen pictures with both any input thanks guys again thank you
Okay II update try to start it it cranks almost starts and that's it last time a couple hours ago it started right up now nothing time for a beer and input greatly appreciate it thank you
are you sure distributor isnt 1 tooth off when u restabbed it.
also could you try again with description. couldnt understand u.
Sorry, yeah I didn't touch the distributor at, gonna see if it needs fuel, gonna throw a gallon in and see, but it was weird ran great , pulled in garage, sat for 15, started no sweat then couple hours .nada..oh well tomorrow
did u repair the vac lines correctly?
Okay started right up this morning barley cranked, but my fan was on immediately and still have that high idle, let it run for about 1/2 he still idle high, gonna wait and see if she starts, really scratching in the fan coming on straight away
did u leave the paperclip in the aldl port
My experience is when the cooling fans start-up on key ON is ECM no see chip !
#33
Seems like it's "Vacuum Line Season" again in Vette-world. After looking at most of mine I have decided to replace most of them with bright green silicone rubber; it may look goofy, but at least I can see where they are and whether or not they're still connected properly. Now I need to figure out where is the best place to permanently connect a vacuum guage under the hood.I remember years back when lots of guys had an aftermarket guage under the dash for monitoring "fuel economy" (like you really needed it when gas was 28 cents a gallon...).
#34
Okay I got the new coolant sensor connector has two wires like they all do I went to splice it mine has two black wires to one terminal and one pink wire so I splice them put the two black wires together to what I believe was the ground side and the pink wire to the hot side started it fan kicked on right away high idle I figure maybe I had two lines reversed took it apart Reese placed back to the other way now it won't start I'm going to try this weekend if I can't get it started anybody in Vegas want to take this off my hands I'm taking offers if I don't get it done by this weekend I'm done with this car interior is immaculate I have two tops extra radiator couple little parts box for other stuff I'm done I just can't deal with it anymore
#36
