LT4 pistons... +030"
Before you guys ask, yes, its an LT4. Not an LT1. Car is pretty much run its course, so Ill be repurposing its guts for my 95 vette.
Ill be making this one a 383 and the top end will be ported while its apart. I have another block ready to go, so I was curious what you guys have been using as a replacement for the LT4 pistons, or if GM has a p/n for an offering at .030 over? That way that rotating assembly can still see some use later on...
Listen, if it is what you say it is, that is a 1 of 108, or more specifically 1 of 100 available in the US. It is a very special car and to part it out rather than restoring it is a big mistake. I would venture you could sell it in it present condition (no matter how worn out it may be) to someone interested in restoring it, at a price that would finance your build for the 95 or cover the cost of buying a 96 and modifying it. Without destroying history.
There is also harmonics in play, Although a crankshaft seems like a very rigid component, it does flex under the varying forces. Each rotating assembly has its own natural frequency much like a tuning fork. Aspects such as crankshaft material, engine stroke, flywheel mass and bearing dimensions determine the natural frequency of a rotating assembly. So, unless you want to do a lot of homework and out engineer experienced engine builders, buying a kit that solves all of this is probably the way to go.
Since you are going so deep into modifications, I don't believe you need to worry about an LT4 specific piston. In the end, it is a SBC. You need to get a solid rotating assembly that works together.
That block casting number is probably going to be worth more than you will spend modifying it.
I dont do kits. Never have. I like personally choosing components, and most of the time find something in them I don't like. I would consider them if Im allowed to substitute components, but usually I do my own thing. Theres no magic to it... and I think its more fun anyway. Gives me a little more control over the end product.
The 383 I already have the rotating assembly for. I have another engine I could use for the LT4 stuff that comes up of it once it comes back from the machine shop.
The factory LT1 pistons are pretty good for what they are. Thats why I was curious is there was an o/s offering for the LT1/ LT4. I could always put some hypers in it and call it a day...just seeing if there is an option from the general.
Are the LT4 pistons made by mahle? I seem to remember something years back about the LT1 pistons being made by them.
Supposedly the engine was out of a GS, but Im not too sure about that one. It was probably just a 96 M6 car, but who knows?
Don't know specifically on the pistons, but the LT4 isn't going to be anything special if you are replacing the overall rotating assembly. Run what you need/want for your build. The LT4 was just an LT1 with a few different (better) components. Once you start changing/modifying the components it's really going to be a built SBC with LT1 architecture. The aftermarket will probably provide better specialized solutions.
Maybe you need to better understand mine!! BLOCK CASTING is very different from VIN derivative. VIN derivative will ID it's originality, OP mentions GS and then just C4 LT4. VIN derivative would confirm which.
I don't have a problem with anything I posted.
Anyway, the plan was to reuse the crank (and perhaps rods if in good shape) with some new pistons in a 355 for something else after building a 383 out of the LT4. I know there are tons of options for pistons, I was just curious if there was a factory piston out there for repair jobs like some crate motors have before I went and looked at other options.
As for building a stroker it depends on what you want to spend really. You could go with a thrifty 1500.00 kit or all forged 9k complete. Mahle, Wisco, JE are a few choices for pistons. You want to work with machine shop so block is bored to piston manufacturer's spec.s and finished for the ring manufacturer's spec.s. Discussing your goals is also an important of the process so there is no preventable disappointment..i.e. Incorrect part selection or non performed machining.
Here are some in 4.040 bore size.
https://karlperformance.com/i-247123...3;brand:101285
https://www.ebay.com/itm/Mahle-22435...8/113635647762
Additionally Speed Pro makes an LTX replacement Hyper piston with the correct metric ring package. PN H597HCP. However they are expensive and so are the rings which are separate.
https://www.jegs.com/i/Sealed-Power/...97DCP/10002/-1
https://www.summitracing.com/ga/part...make/chevrolet
Will
I see that stock LT1 pistons are made with Eutectic Aluminum/Silicon Alloy in my research. Is that considered an upgrade to a stock cast piston, but not as good as "forged" piston?
Some people get away with a lot on them in boosted LS applications for a while. Some people find out why most engine builders refer to the (not so) jokingly as "Hyperexplosives".
Will
Will
Friends brand new 347 let go at 35 mph (hypers) there was nothing left of the engine that was useable, block, crank, cam in a few pieces, carb etc.Like a bomb went off.
I tend not to push the limits of what amounts to stock replacement parts.... I don't like to see my stuff blow up and as has been said, when hypers let go it's usually total destruction.
Will
Myself I think you should save yourself the cost of alignhone or alignbore and keep the LT4 assembly in the LT4 block then put the LT4 heads on the stroked LT1 block. That way you reuse the PM LT4 rods also.
Hope this helps.
