92 lt1 stumbles under heavy acceleration
Whole story.
I bought the car from a mechanic for $150+ a diamond wrist watch.
It wouldnt start.
The fuel pump and sending unit was rusty.
I cleaned out the fuel tank by hand. And replaced the pump and sending unit. Still no start.
I replaced the fuel filter and regulator. It would start but shut off after a second or two.
I took the injectors out and DIY you tube style cleaned them. The car finally ran but bad under heavy acceleration (Sometimes).
I then replaced the spark plugs, coil and opti spark (autozone duralast lifetime warranty) runs ok not good while cold but gets worst after warming up.
I checked these sensors while running.
Idle air temp sensor. No difference
trottle position sensor. idle raised
ignotion control module. Shuts off
optispark connection under fuel rail. Shuts off
egr connection. No difference
coolant temp sensor. Fan turns on
Each injector connector. Stumples at idle after I disconnected each one by one.
I don’t have a fuel pressure gauge
You are going to need one to do a leak down test and then you need to do a resistance test to know they are good. If you are comfortable they are clean you can eliminate that issue but it doesn't mean they function properly. Even if it isn't the issue today, it may be an issue soon. Seems the TPI cars started to have a lot of issues in the 25-30 year range. You car is about to hit that window.
Probably your issue, do some reading around here. The Duralast usually fails frequently. The warranty is good for getting free parts, but it doesn't keep you from breaking down or having to do the replacement. I suggest you send your old stock unit out for rebuild. Read around and decide on your source. Though, before you go through all the labor to swap it out again, please do some troubleshooting. It may not be your issue, but I would still get your old one rebuilt to keep as a spare. The Duralast seems to have a 90% chance of failing based off what others have posted.
Have you reset your computer yet (Pull the negative battery cable for about 10 seconds)
That doesn't mean a lot. You still don't know if one has a problem.
All good stuff... any codes?
You should also test voltage at the pump, make sure it is not a wiring issue.
This doesn't rule out you having an unhealthy Opti, but that fuel pressure is definitely low. While it may be your regulator, less pressure at higher RPMs is usually a volume problem from the pump. Replacing the regulator would also not be a bad idea given the age of the cars, it's pretty accessible and cheaper than a pump. While I am not a fan of throwing parts at a problem, changing the regulator and filter with a new pump is cheap/easy to prevent future problems.
I’ve stuck with OEM AC Delco on any of my F-bodies and C4’s and never had an issue...
